Check if part is a native Autodesk Inventor document (iam, ipt or idw.dwg)
isocam
isocam
Can anybody help?
If I open, using Autodesk Inventor, a SolidWorks/SolidEdge/Catia etc document (assembly, part or drawing), is it possible using an Inventor VBA macro, to check if the opened part is not a native Autodesk Inventor document?
Many thanks in advance!!!
Darren
k14348
     you may check file name extension to find this.
-Karth
isocam
Karth,
If you import a SolidWorks document into Inventor the filename extension sldpt, for example, gets automatically converted to the Inventor file name extension ipt, so using the filename extension you mentioned will not work.
Kind Regards
Darren
tobias.orlow
Hi @isocam ,
Please check the following blog post related to Imported Components:
https://adndevblog.typepad.com/manufacturing/2015/10/get-fullfilename-of-original-anycad-component.h...
Let me know if that helps or if you need further help.
Many thanks,
Tobias
Tobias Orlow
Designated Support Specialist
Customer Success Organization
Linkedin: www.linkedin.com/in/tobiasorlow/
k14348
    In that case, For opened doc u go to workspace path then check the folder file extension using api.
Hope by this way u may able to get solution.
-Karth
JelteDeJong
I dont have a (SolidWorks/SolidEdge/Catia) file to test with but when i import a step file there is usaly a converion log thing in the model browser. you could check with code if its there.
If you can share a none confidential SolidWorks/SolidEdge/Catia file. Maybe then i can help you a bit more.
Jelte de Jong
Blog: hjalte.nl - github.com
