Check BOM browser is opened
dibujocad
dibujocad
Hi, I need to check if BOM browser is opened in the active assembly.
I found this code to execute it, but I cannot find anything related to check if it's opened.
Any suggestion?
ThisApplication.CommandManager.ControlDefinitions.item("AssemblyBillOfMaterialsCmd").execute
matt_jlt
only thing i can think of is using the windows / win32 API which is not really a simple implementation
look at this post from a while ago for a starting point.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/get-vault-check-in-window/m-p/10629398/...
Essentially you would have to call a command that gets the active windows and looks for one that has either a complete or partial name match to the one you want.
Ralf_Krieg
Hello
AFAIK as long as the BOM window is open, ThisApplication.CommandManager.ActiveCommand="AssemblyBillOfMaterialsCmd".
R. Krieg
RKW Solutions
www.rkw-solutions.com
matt_jlt
I didn't even think of doing that, genius. Thanks for the tip.
dibujocad
Thanks!! It's exactly what I was looking for
