check assembly for custom properties, and list all unik string
Darkforce_the_ilogic_guy
Advisor Advisor
I have a code that find all custom properties (Raw Material) .   in an assembly and it parts. but I only want to have each properties one time for each unik vaule/ string
I want to create a list of all type of material that are use in the assembly
any go way to do this ?
Class BOMEXport
Shared oMaterial As String
Shared oMaterialName As String
Sub main()
	oMaterial = ""
	oMaterialName = ""
PossibleIssueReport()
End Sub
Sub PossibleIssueReport()
	Row2 = 3
	Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
Call ExportToExcel(oBOMView.BOMRows)
End Sub
Public Function ExportToExcel(brows As BOMRowsEnumerator)
	Dim brow As BOMRow
For Each brow In brows
	Dim rDoc As Document
rDoc = brow.ComponentDefinitions.Item(1).Document
Dim docPropertySet1 As PropertySet
docPropertySet1 = rDoc.PropertySets.Item("User Defined Properties")
Try
	oMaterialName = ""
	If docPropertySet1.Item("Raw Material").Value = "3916030054" Then
		oMaterialName = "RHP 50x30x4"
	If docPropertySet1.Item("Raw Material").Value = "3916050106" Then
		oMaterialName = "RHP 100x50x6"
	oMaterial  = (oMaterial +  vbLf  + docPropertySet1.Item("Raw Material").Value) + " " + oMaterialName
	Catch
	End Try
	Next
	msgbox (oMaterial)
	End Function
End Class
J-Camper
I think a NameValueMap is what you want.  It throws an error when trying to add a Name that already exists.  With a Try/Catch you can build a list for each unique material:
Class BOMEXport
Shared OutputMap As NameValueMap
Sub main()
	oMaterial = ""
	oMaterialName = ""
	OutputMap = ThisApplication.TransientObjects.CreateNameValueMap
End Sub
Sub DisplayOutputMap()
	Dim Message As String
	For j = 1 To OutputMap.Count
		Logger.Trace(OutputMap.Name(j) & " : " & OutputMap.Value(OutputMap.Name(j))) 'Set Log Level to Trace for selectable output
		Message += vbLf & OutputMap.Name(j) & " : " & OutputMap.Value(OutputMap.Name(j))
	Next
	MsgBox (Message)'Modified Output
End Sub
	Row2 = 3
	Dim oBOM As BOM
End Sub
	Dim brow As BOMRow
		Try
			oMaterialName = ""
			Try
				OutputMap.Add(oMaterialName, docPropertySet1.Item("Raw Material").Value)
			Catch
				'Name is already taken. Add handling if you want to modify value to indicate multiple instances
			End Try
		Catch
		End Try
	Next
	DisplayOutputMap()'Modified Output first
	MsgBox (oMaterial)'Current
	End Function
End Class
Let me know if you have any questions or if this is not working as intended.
it fix one problem.  but I now I have 2 other problem.
First the 2 text does not line up very vel.  Second  it would be nice to sort them.
J-Camper
@Darkforce_the_ilogic_guy,
I wish there was a sort method on the namevaluemap.  I'm not sure if this is the easiest/best way to sort it, but it think it works in this situation.  Since the Value Object is a String in your application, you can put the namevaluemap into a List(Of String) with a known separator String, Sort the List, then fill the namevaluemap back with the sorted list.
As for the Offset text you are seeing, I'm only putting " : " between the name/value in the message box so I don't know where all those extra spaces are coming from.  Do they exist in the iLogic Log or just the message box?
In any case I added a sub routine to sort the namevaluemap [for Values of type string, or can be converted to string only].  here is the new sub and a modified Display sub to call the Sort sub:
Sub AlphaSortMap()
	Dim SortingList As New List(Of String)
	Dim seperator As String = " <|> "
		SortingList.Add(OutputMap.Name(j) & seperator & OutputMap.Value(OutputMap.Name(j)).ToString)
	Next
	SortingList.Sort()
	OutputMap.Clear()
	For Each s As String In SortingList
		OutputMap.Add(Left(s, s.IndexOf(seperator)), Right(s, s.Length-s.IndexOf(seperator)-seperator.Length))
	Next
End Sub
AlphaSortMap()
	Next
End Sub
