Check a point is up or down with a plane
SandmanINV
SandmanINV
I have a Plane. This Plane through center of mass point.
And I have a Point. How can I check that point is up side or down side of that plane ?
Thank you very much,
JhoelForshav
Hi @SandmanINV
I don't know exactly how you define over/under the plane. If its about the Z-position you can use this rule:
Dim oPlane As WorkPlane = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Pick plane.")
Dim oPoint As WorkPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Pick point.")
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oLine As Line = oTG.CreateLine(oPoint.Point, oTG.CreateVector(0, 0, 1))
Dim oIntPoint As Point = oLine.IntersectWithSurface(oPlane.Plane).Item(1)
Select Case oIntPoint.Z
	Case > oPoint.Point.Z
		MsgBox("Point is under plane")
	Case < oPoint.Point.Z
		MsgBox("Point is over plane")
	Case oPoint.Point.Z
		MsgBox("Point is on plane")
End Select
If it's about the planes normal, where over plane means that the point is in positive normal direction from the plane you can use this rule:
Dim oLine As Line = oTG.CreateLine(oPoint.Point, oPlane.Plane.Normal.AsVector)
If oIntPoint.IsEqualTo(oPoint.Point)
Else
If oIntPoint.VectorTo(oPoint.Point).AsUnitVector.IsEqualTo(oPlane.Plane.Normal)
Else
SandmanINV
I will code follow your guide number 1. Creating Unit vector to do that. So coool.
Thanh you very much Mr @JhoelForshav
Maxim-CADman77
@JhoelForshav
Could you, please, share how can forum user publish colored iLogic code?
Please vote for Inventor-Idea Text Search within Option Names
