Changing unit of measure in Inventor 2018 BOM
jeremydoyle
jeremydoyle
I need to change my units in Inventor BOM, for beams, from linear inches to linear feet.  Is this possible in Inventor 2018? thank you for the help.
webstgk
Observer
Observer
Double Click the BOM in your drawing to open the parts list editor.  Select the column header where your inch dimensions appear, right click, and choose FORMAT COLUMN.  Pick the radio button "Apply Units Formatting," and change the units to ft.  You can then adjust the format and precision as you see fit.
