Changing the size of a drawing sheet
I'm trying to set the heigh of my sheet to 20% bigger than the height of the view, but i get the following errors:
Anyone know what i'm doing wrong?
Error on Line 5 : Property 'Size' is 'ReadOnly'.
Error on Line 6 : Property 'Height' is 'ReadOnly'.
SyntaxEditor Code Snippet
Height = ThisDrawing.Sheet("Sheet:2").View("1To1").Height
Width  =  ThisDrawing.Sheet("Sheet:2").View("1To1").Width
With ThisDrawing.Sheet("Sheet:2")
    .Size = DrawingSheetSizeEnum.kCustomDrawingSheetSize
    .Height = Round(Height*1.2,0)
End With
 Regards
Mark
frederic.vandenplas
Try to declare your sheet first and then modify the options
Dim odrawdoc As DrawingDocument
odrawdoc = ThisApplication.ActiveDocument
Dim osheet As Sheet
osheet = odrawdoc.ActiveSheet
With osheet
	.Size = kCustomDrawingSheetSize
	.Width = 100
	.Height = 100
End With
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Thanks.
...but how do i define sheet 2? It's unlikley to be the activesheet
Regards
Mark
frederic.vandenplas
Now i see your error, you need to add a S to Sheet
odrawdoc.Sheets("Sheet:2") instead of
odrawdoc.Sheet("Sheet:2")
Dim osheet As Sheet
osheet = odrawdoc.Sheets("Sheet:2")
With osheet
	.Width = 100
	.Height = 100
End With
Thanks.
I had tried that, but forgot the "s" on the end of Sheet
doh!
