Changing the line thickness of a drawing
kv5053545
kv5053545
I am working with automatic drawings in Autodesk inventor, but I would like to uncheck the option "By Layer" that is inside the properties of the assembly that is inside the view, is it possible to do it by code?
J-Camper
@kv5053545,
I'm not sure that box is accessible through the API, not all options are exposed.  You can change the DrawingCurve LineWeight without checking/un-checking that box:
Dim MyDrawingView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a DrawingView")
If MyDrawingView Is Nothing Then Exit Sub
For Each dc As DrawingCurve In MyDrawingView.DrawingCurves
	dc.LineWeight = .2 'Default Value: dc.Segments.Item(1).Layer.LineWeight
Next
This is will change all the DrawingCurves of a user selected DrawingView.
Let me know if you have any questions
