Changing Part material and appearance inside Assembly with iLogic
Daan_M
Daan_M
I am trying to change the material and appearance (color) of all parts inside my assembly, so they all have the same color and it looks tidy.
Right now i am trying to check all referenced part documents and change their material/appearance. It seems like the material part is working, but im not sure how to adjust the appearance/color. I'm accessing the appearance the wrong way, i tried looking in the API object model but haven't managed to find it.
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim pDoc As Document
Dim oMaterialName As String = "Generic"
Dim oAppearanceName As String = "Default"
Dim oMaterial As Material = oDoc.Materials.item(oMaterialName)
Dim oRenderStyle As RenderStyle = oDoc.RenderStyles.Item(oAppearanceName)
For Each pDoc In oDoc.AllReferencedDocuments
	If pDoc.DocumentType = kPartDocumentObject
		Dim oPartDoc As PartDocument = pDoc
		oPartDoc.ComponentDefinition.Material = oMaterial
		oPartDoc.ComponentDefinition.ActiveRenderStyles = oRenderStyle
Next
Maybe i can do something with the Assets? API object models sais this has to do with the appearance and color, but i'm also not sure how to use this any further;
Dim oAsset As Asset = oDoc.Assets 'not sure how to complete the code here
Any tips how i can get all parts in my document the same color and material? Thanks
JelteDeJong
This will not colour the documents themselves but the components in the assembly.
Dim doc As AssemblyDocument = ThisDoc.Document
Dim asset As Asset = doc.Assets.Item("Default")
For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences
    occ.Appearance = asset
Next
Jelte de Jong
Blog: hjalte.nl - github.com
