Changing only the UI to english
Hello everyone,
I'm new to inventor 2018 and still adjusting to the new software.
I'm working in germany but I prefer my user interface to be in English.
Hence I downloaded the english language pack. But it resulted in everything being changed to german such as the Parts list or the revision table column or the standard parts names.
I'm requried to produce all the drawings in German and because of this I end up renaming all the standard components I'm using. Is there a way where I change only the user interface to English but the rest remains in German?
Prasanna
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
In a system, multiple Inventor with different language is possible.
Try to install Language packs available for Inventor 2018 in the following link.
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-2018-language-packs.html
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thanks for the information. But like I said, I already downloaded the engish version of Inventor 2018 and installed it. But what it does is, it changes all the background items to english.
For example - when I'm placing a standard part from the content centre, the parts name is in english and when I make a drawing and import the parts list, the items names appear in English as well. For example, the revision tabe column header also appear in english which I want in German as everyrhing must be in German.
What I want is, only the user interface should be in english and everything else should remain in german.
Is there a way to do it?
Regards
Prasanna
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Sorry for inconvenience,
Partial localization(translation) of Inventor Application is not possible.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Thanks for the help.
I think the only way is for me to go back to the German version of Inventor.
Regards
Prasanna
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
German version would better idea to use.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
