Changing Drawing Curves to Match Assembly Color
Hello
ist there a way to make set the drawing layers with part colors?
NSBowser
Check out this post on ModTheMachine. He's doing something similar to what you are looking for. I don't believe it adjusts layers as much as individual line settings.
http://modthemachine.typepad.com/my_weblog/2010/10/changing-drawing-curves-to-match-assembly-color.h...
Best of Luck!
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
