Changing Component Pattern Visibility.
herrwolf1
herrwolf1
     I'm trying to create a custom "Design View Representation". Is there a way to determine if a leaf occurrence is part of a component pattern? Whether or not that capability is available, how do you change the visibility state of a given pattern?
Thank you
Eric.
montylowe
Any Luck On this one?
herrwolf1
Sure did.
Dim oOccs As ComponentOccurrencesEnumerator
Dim oOcc As ComponentOccurrence
oOccs = oAsmDef.Occurrences.AllReferencedOccurrences(oSubRefDoc)
For Each oOcc In oOccs
If oOcc.IsPatternElement Then
     Dim oCcPat As OccurrencePattern
     oCcPat = oOcc.PatternElement.Parent
     If oCcPat.Visible Then
          oCcPat.Visible = False
          Continue For
Enjoy,
montylowe
Having issue with
oOccs = oAsmDef.Occurrences.AllReferencedOccurrences(oSubR​efDoc)
Where do you define these items?
oAsmDef
(oSubR​efDoc)
herrwolf1
        ' Get the active assembly.
        Dim oAsmDoc As AssemblyDocument
        oAsmDoc = Application.ActiveDocument
        ' Get the assembly component definition.
        Dim oAsmDef As AssemblyComponentDefinition
        oAsmDef = oAsmDoc.ComponentDefinition
_____________________________________________
 ' Get the sub assembly referenced documents.
Dim oSubRefDocs As DocumentsEnumerator
oSubRefDocs = oRefDoc.AllReferencedDocuments
' Iterate through each sub component of the sub assembly.
Dim oSubRefDoc As Document
For Each oSubRefDoc In oSubRefDocs
leblanc2024
For those interested... Here is a VBA version of the code above...
Public Sub PATTERNvis()
Set oAsmDoc = ThisApplication.ActiveDocument
Set oAsmDef = oAsmDoc.ComponentDefinition
Set oSubRefDocs = oAsmDoc.AllReferencedDocuments
     Set oOccs = oAsmDef.Occurrences.AllReferencedOccurrences(oSubRefDoc)
          Set oCcPat = oOcc.PatternElement.Parent
          If oCcPat.VISIBLE = False Then
               oCcPat.VISIBLE = True
               'Continue For
     Next
Next
End Sub
Ivon
"You don't know if you can unless you try!"
