changing BOMStructure via iLogic within one line
Kay_Rethmeier
Kay_Rethmeier
I'm able to change the BOM Structure within a single line from default to reference. But the other possibilities doesn't work. Any ideas to have a change within a single line?
SyntaxEditor Code Snippet, these two are working!!!!
Component.InventorComponent("MyPart").BOMStructure = BOMStructureEnum.kReferenceBOMStructure
Component.InventorComponent("MyPart").BOMStructure = BOMStructureEnum.kDefaultBOMStructure
  But these aren't working:
Component.InventorComponent("MyPart").BOMStructure = BOMStructureEnum.kPhantomBOMStructure
Component.InventorComponent("MyPart").BOMStructure = BOMStructureEnum.kNormalBOMStructure
 Thanks in advance!
Kay
Cheers
Kay (Principal CAD-Consultant)
Kay_Rethmeier
Hi agian,
OK, some next informations:
my two lines at the beginning are switching the compontents inside the assembly (manually done within the browser).
It isn't possible to use the other options (kInseparableBOMStructure, kPurchasedBOMStructure, kPhantomBOMStructure, kNormalBOMStructure) here. So far so good.
But maybe somone has an idea to shorten the rule from this:
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
	If oOccurrence.Name = "MyPart" Then
		oOccurrence.Definition.BOMStructure = kInseparableBOMStructure
Next
 to a single line. It will be perfect if a coulpe of BOM manipulations have to be done.
Ciao
Kay
Cheers
HermJan.Otterman
Hello Kay,
maube this will help:
use sub's, the first will need to be called "Main"
Sub main
	'one line that call an other sub
	changeToReference("MyPart")
	changeToReference("MysecondPart")
	'etc
End Sub
Sub changeToReference(ByVal occurrenceName As String)
	If oOccurrence.Name = occurrenceName Then
		oOccurrence.BOMStructure = kReferenceBOMStructure
Next
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
