Changing Asset Value Fails
Dim oAppAsset As Inventor.Asset
                oAppAsset = m_inventorApplication.AssetLibraries.Item _
                    ("Autodesk Appearance Library").AppearanceAssets.Item("Machined 03")
                oPartDoc.ActiveAppearance = oAppAsset
                Dim oNewAsset As Inventor.Asset
                oNewAsset = oPartDoc.AppearanceAssets.Item("Machined 03")
                Dim oValue As AssetValue
                oValue = oNewAsset.Item("generic_bump_map")
                Dim oColorValue As ColorAssetValue
                oColorValue = oValue
                oColorValue.HasConnectedTexture = False
 The above failed while changing the HasConnectedTexture. please help to overcome this.
YuhanZhang
This is known issue and logged as defect ID 1496049 in our internal defect system. Please provide the ID number to check the status of the defect.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
