Change visibility for Surfaces in an Assembly
They_Call_Me_Jake
They_Call_Me_Jake
Not sure what I'm doing wrong or if it is a bug but if I could get some help I would appreciate it. I have and Assembly with some Sub-Assemblies in it. In those Sub-Assemblies are some parts with surfaces that where from copying other parts into it. We use those copied in surfaces to do a sculpt but it leaves the surface visible. I have tried numerous ways to try and turn off the visibility but nothing I try seems to work. Does anyone have an idea of what I am doing wrong here.
Sub Main()
	Dim oAsm = ThisDoc.Document
	Dim oAsmDef As ComponentDefinition = oAsm.ComponentDefinition
	HideCompositeSurfaces(oAsmDef, "Carriage Base:1")
End Sub
Sub HideCompositeSurfaces(oAsmDef As ComponentDefinition, targetName As String)
	Dim target As ComponentOccurrence = Nothing
	Dim oLeafOccs As ComponentOccurrencesEnumerator = oAsmDef.Occurrences.AllLeafOccurrences
	Dim oOcc As ComponentOccurrence
    For Each oOcc In oLeafOccs
        If oOcc.Name = targetName Then
			target = oOcc
	Next
	Dim oContainingOccurrence As ComponentOccurrence = target.ContainingOccurrence
	Dim oContainingOccurrenceDef As ComponentDefinition = oContainingOccurrence.Definition
	For Each oWorkSurface In target.Definition.WorkSurfaces
'			Dim oWorkSurfaceProxy As WorkSurfaceProxy = Nothing
'			oContainingOccurrence.CreateGeometryProxy(oWorkSurface, oWorkSurfaceProxy)
			oWorkSurface.Visible = False
		Next
End Sub
WCrihfield
It sounds to me like you might benefit from setting up DesignViewRepresentations at each level of the assembly structure, starting with the part.  Create a DVR in the Part, then turn those surfaces off, and that DVR will record that setting.  Then in the sub assembly, create a DVR, and set the component representing that part to the DVR you created in the part, and that setting will be recorded in its DVR.  Then in your top assembly, create a DVR and set the component that represents the sub assembly to its DVR.  That's the normal, manual way of handling those sorts of things.
Wesley Crihfield
(Not an Autodesk Employee)
They_Call_Me_Jake
@WCrihfield thanks for the reply. I'm wanting to do this thru code instead of manually. I have actually done this before and I have copied my code that does in fact work into this iLogic rule but for some reason it's not working here when it works in external code.
