Change value of TextBox.Text
mr_ensing
mr_ensing
The situation: Drawing --> Sheet --> View -->  Sketch --> TextBoxes
These TextBoxes need changing, on several drawings. Not that complicated, it seems.
But the line that does the actual work (oTextbox.Text = "TEST") refuses to work. The TextBox.Text property is read/write, so what's the problem?
Private Sub ChangeTextboxText()
    'drawing
    Dim idwDoc As DrawingDocument
    Set idwDoc = ThisApplication.ActiveDocument
    'active sheet
    Dim oSheet As sheet
    Set oSheet = idwDoc.ActiveSheet
    'loop views
    Dim oView As DrawingView
    For Each oView In oSheet.DrawingViews
        'loop sketches
        Dim oSketch As sketch
        For Each oSketch In oView.Sketches
            'loop textboxes
            Dim oTextbox As TextBox
            For Each oTextbox In oSketch.TextBoxes
                'change text
            Next oTextbox
        Next oSketch
    Next oView
End Sub
JhoelForshav
Hi @mr_ensing
You'll have to edit the sketch in order to change the text 🙂
            'loop textboxes
            Dim oTextbox As Inventor.TextBox
                'change text
				oSketch.Edit
                oTextbox.Text = "Test"
                oSketch.ExitEdit
            Next oTextbox
        Next oSketch
mr_ensing
That's it! Thanks a bunch.
