07:54 AM
I have put together a piece that performs these steps:
- open part drawings as they appear on a parts list
- add information to those part drawings from the parts list
- send part drawings to a PDF printer
- close file and go to next part in parts list
We have recently changed made a new part print template with a new titleblock. I would like this rule to check the title block and replace it if it isn't current (based on title block name). I have not found a way to do so. I can read the title block name. I can delete the title block from the open drawing. I cannot place a new title block. The ActiveSheet.TitleBlock command won't let the rule run because "Titleblock is ReadOnly". Help?
Allen
'Release 1.0 February 3, 2016 Imports System.IO Sub Main() ThisApplication.SilentOperation = True ActiveSheet = ThisDrawing.Sheet("Cut Sheet:1") Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oDrawingView As DrawingView Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oPartList As PartsList Dim path As String Dim PartNum As String Dim FileLoc As New DirectoryInfo("C:\Yargus Working Folder\Projects") PageNumber = 1 CoverSheetPage2: oDrgPrintMgr = oDrawDoc.PrintManager oDrgPrintMgr.Printer = "PDFCreator" oDrgPrintMgr.PrintRange = kPrintCurrentSheet oDrgPrintMgr.AllColorsAsBlack = False oDrgPrintMgr.ScaleMode = kPrintBestFitScale 'oDrgPrintMgr.ScaleMode = kPrintModel oDrgPrintMgr.ColorMode = kPrintDefaultColorMode oDrgPrintMgr.PaperSize = SizeActiveSheet oDrgPrintMgr.SubmitPrint If PageNumber = 1 Then Try ActiveSheet = ThisDrawing.Sheet("Cut Sheet:2") PageNumber = 2 Goto CoverSheetPage2: Catch End Try End If ActiveSheet = ThisDrawing.Sheet("Cut Sheet:1") PageNumber = 1 'Get information from text boxes in the sheet title oTitleBlock = oSheet.TitleBlock oTextBoxes = oTitleBlock.Definition.Sketch.TextBoxes For Each oTextBox In oTextBoxes If oTextBox.Text = "<Work Order>" Then WO = oTitleBlock.GetResultText(oTextBox) End If If oTextBox.Text = "<Customer Info Line 1>" Then Customer = oTitleBlock.GetResultText(oTextBox) End If If oTextBox.Text = "<Customer Info Line 2>" Then Location = oTitleBlock.GetResultText(oTextBox) End If If oTextBox.Text = "<FILENAME>" Then Assy = oTitleBlock.GetResultText(oTextBox) End If Next CutSheetPage2: If PageNumber = 2 Then Dim oSheet2 As Sheet = oDrawDoc.ActiveSheet oPartList = oSheet2.PartsLists(1) Else If PageNumber = 1 Then oPartList = oSheet.PartsLists(1) End If For Each oPartListRow In oPartList.PartsListRows If oPartListRow.Visible = "True" And oPartListRow.Custom = "False" Then oCell = oPartListRow.Item(" QTY") QTY = oCell.Value oCell2 = oPartListRow.Item("LENGTH (in)") Length = oCell2.Value oCell3 = oPartListRow.Item("WIDTH (in)") Width = oCell3.Value oCell4 = oPartListRow.Item("PART NUMBER") PartNum = oCell4.Value & ".idw" path = SearchFile(FileLoc, PartNum, 0) If path <> "" Then ThisApplication.Documents.Open(path, True) Else If path = "" Then MessageBox.Show("The drawing was not found and will be omitted from the plot stamp.", "File Not found") Goto MOVEON: End If Dim oDrawDoc2 As DrawingDocument = ThisApplication.ActiveDocument 'Place text with information for each drawing Dim oActiveSheet As Sheet oActiveSheet = oDrawDoc2.ActiveSheet TB = oActiveSheet.TitleBlock If TB.Name <> "Yargus 2016" Then MessageBox.Show("This drawing has an out of date drawing template. Please Review.", PartNum) End If 'use PaperSizeEnum from inventor programming help PageSize = oActiveSheet.Size If PageSize = 9990 Then 'Size is ANSI D PageSize = 14347 End If If PageSize = 9987 Then 'Size is Letter (A) PageSize = 14353 End If If PageSize = 9988 Then 'Size is 11x17 (B) PageSize = 14338 End If If PageSize = 9989 Then 'Size is ANSI C PageSize = 14346 End If Dim oGeneralNotes As GeneralNotes oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry Dim oGeneralNote As GeneralNote x=0 If PageSize = 14347 Then x = 58.5 Else If PageSize = 14346 Then x = 28 Else If PageSize = 14338 Then x = 15.25 End If oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3.27+x, 4.28), QTY) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(7+x, 4.28), Assy) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(13.75+x, 4.28), WO) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(11.75+x, 3.65), Length) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(15.75+x, 3.65), Width) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(2.7+x, 2.95), Customer) oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(11+x, 2.95), Location) 'End insert text onto drawing oDrgPrintMgr2 = oDrawDoc2.PrintManager oDrgPrintMgr2.Printer = "PDFCreator" oDrgPrintMgr2.PrintRange = kPrintAllSheets oDrgPrintMgr2.AllColorsAsBlack = False oDrgPrintMgr2.ScaleMode = kPrintBestFitScale 'oDrgPrintMgr.ScaleMode = kPrintModel oDrgPrintMgr2.ColorMode = kPrintDefaultColorMode oDrgPrintMgr2.PaperSize = PageSize oDrgPrintMgr2.SubmitPrint oDrawDoc2.Close(True) End If MOVEON: Next If PageNumber = 1 Then Try ActiveSheet = ThisDrawing.Sheet("Cut Sheet:2") PageNumber = 2 Goto CutSheetPage2: Catch End Try End If ActiveSheet = ThisDrawing.Sheet("Cut Sheet:1") MessageBox.Show("Plot Stamp Has Completed Successfully!", "Finished") End Sub Function SearchFile(ByVal SearchDir As DirectoryInfo, ByVal searchFileName As String,i As Integer) As String Static Dim FoundPath If i = 0 Then FoundPath = "" i = 1 End If If FoundPath = "" Then Dim temp As String = "" If SearchDir.GetFiles(searchFileName).Length > 0 Then FoundPath = SearchDir.FullName & "\" & searchFileName Return SearchDir.FullName & "\" & searchFileName End If Dim Directories() As DirectoryInfo = SearchDir.GetDirectories("*") For Each newDir As DirectoryInfo In Directories temp = SearchFile(newDir, searchFileName,i) Next Return temp Else Return FoundPath End If End Function
