Change the thickness of lines in a view in a dwg drawing.
kv5053545
kv5053545
I am working on a DWG drawing, I have been trying to make the lines of the views thinner, I have this code, but it takes too long, I do not know if you can guide me to optimize my code or if there is a way to define it from the template so that the views have thinner lines, I would appreciate your help.
	Dim drawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim lineThickness As Double = 0.01
For Each sheet As Sheet In drawingDoc.Sheets
    For Each view As DrawingView In Sheet.DrawingViews
        For Each line As DrawingCurve In View.DrawingCurves
            Line.LineWeight = lineThickness
        Next
    Next
Next
This is how the view looks like when placed in the drawing.
daltonNYAW9
You could just change the thickness in the styles editor.
Manage>Styles Editor>Layers>Line Weight
By default the lines in the views (for me) are "Visible (ANSI)" and "Visible Narrow (ANSI)". I don't think inventor is optimized to change the lines the way you are doing it. Either use the styles (recommended) or the properties option when you right click a line.
kv5053545
Is it possible to enter from code to that part of the style editor?
daltonNYAW9
drawingDoc.StylesManager.Layers.Item("Visible (ANSI)").LineWeight = 0.01
drawingDoc.StylesManager.Layers.Item("Visible Narrow (ANSI)").LineWeight = 0.01
kv5053545
Thank you very much it worked perfect.
kv5053545
hi @daltonNYAW9 ,
Do you know if also by means of code can be changed the type of line, that if it is Dashed is Continuous?
