change the quantity of a virtual part in a assembly, VB.net
davidt162003
davidt162003
I was trying to add a virtual bolt part onto my BOM which i was able to do however i couldn't change the quantity of the bolts in the bom.
Dim VirtualBoltMatrix = _App.TransientGeometry.CreateMatrix
Dim VirtualBolt = MyAssyDef.Occurrences.AddVirtual("Bolt", VirtualBoltMatrix)
For Each pBomRow As BOMRow In MyAssyDef.BOM.BOMViews(1).BOMRows
    Dim oCompDef = pBomRow.ComponentDefinitions(1)
    Dim PartName = oCompDef.PropertySets.Item("Design Tracking Properties").Item("Description")
    If PartName <> "Bolt" Then
    Else
        Dim pBoltQuantity As [Property] = oCompDef.PropertySets.Item("Design Tracking Properties").Item("Quantity")
        pBoltQuantity.Value = .Flange_NU
Next
 This is what i tried but i get a  error when looking for property set on the component definition i found
HII
A.Acheson
Hi @davidt162003
Bom Qty is sourced from the BOMRow and not an iproperty.
Dim Qty As String = pBomRow.TotalQuantity
Regards
Alan
