Change the pattern browser names
bhavik4244
bhavik4244
Hello there,
I want to change 2nd letter from right for pattern  and rename browser node like shown in below image.
@JhoelForshav  has help me but I want it like this way.
Thanks!
Bhavik Suthar
JhoelForshav
Hi @bhavik4244
Sorry, I just saw that you requested something else in your previous thread, is that still something you need help with?
I didn't really understand that well how you wanted it to work...
For this question though, I think something like this should do the trick? 🙂
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oPattern As OccurrencePattern = oAsm.ComponentDefinition.OccurrencePatterns(1)
Dim oAlphabet As String() = {"A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", _
"L", "M", "N", "O", "P", "Q", "R", "S", "T", "U", "V", "W", "X", "Y", "Z" }
For i = 1 To oPattern.OccurrencePatternElements.Count
	Dim n As Integer = 1
	For Each oOcc As ComponentOccurrence In oPattern.OccurrencePatternElements(i).Occurrences
		oOcc.Name = oAlphabet(n - 1) & i & n.ToString("00")
		n += 1
	Next
Next
WCrihfield
Looks like I'm a few minutes too late, but here is what I was working on for your situation.
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oPatt As OccurrencePattern = oADef.OccurrencePatterns.Item("Component Pattern 8:1")
Dim oAlpha() As Char = "ABCDEFGHIJKLMNOPQRSTUVWXYZ".ToCharArray
Dim oLetter As Char
For oEl As Integer = 1 To oPatt.OccurrencePatternElements.Count
	Dim oElement As OccurrencePatternElement = oPatt.OccurrencePatternElements.Item(oEl)
	'first loop through components to rename them with first two characters
	For oInt1 As Integer = 1 To oElement.Occurrences.Count
		Dim oOcc As ComponentOccurrence = oElement.Occurrences.Item(oInt1)
		oLetter = oAlpha(oInt1)
		oOcc.Name = oLetter & oEl
	Next
	'second loop through (in reverse) to rename again, adding last two characters
	Dim oCounter As Integer = 1
	For oInt2 As Integer = oElement.Occurrences.Count To 1 Step -1
		Dim oOcc As ComponentOccurrence = oElement.Occurrences.Item(oInt2)
		oOcc.Name = oOcc.Name & oCounter.ToString("00")
	Next
Next
Wesley Crihfield
(Not an Autodesk Employee)
JhoelForshav
Oh!, I missed that the last number should be counting down.
Modified code below:
	Dim n As Integer = 0
	Dim p As Integer = oPattern.OccurrencePatternElements(i).Occurrences.Count
		oOcc.Name = oAlphabet(n) & i & p.ToString("00")
		n += 1
		p -= 1
	Next
Next
bhavik4244
@JhoelForshav
@WCrihfield
you're almost there. But,  need my first alphabet to be constant in pattern element whereas with this code, it replace to order A, B, C, likewise. It can be some time P. B, N, K in any order. in short, fist letter correspond to the first component, and likewise others elemets as well.
It can be like this also,
very close to the solution but not completely correct! please have a look.
I highly appriciate your efforts.
Bhavik Suthar
JhoelForshav
@bhavik4244
If I understand correctly, the names of the first pattern element are already set? So you want to change that one, just extract the lettering sequence from it and apply it to the other elemets?
Something like this?
Dim oLetters As String
		If i = 1
			oLetters = oLetters & oOcc.Name.Chars(0)
		Else
			oOcc.Name = oLetters.Chars(n) & i & p.ToString("00")
		n += 1
		p -= 1
	Next
Next
Or like this to still set the numbering of the first element but keep the first letter:
		If i = 1
			oOcc.Name = oOcc.Name.Chars(0) & i & p.ToString("00")
		Else
		n += 1
		p -= 1
	Next
Next
bhavik4244
@JhoelForshav
Awesome!!! This is what I exactly want.
Many thanks,
		If i = 1
		Else
		n += 1
		p -= 1
	Next
Next
Bhavik Suthar
