Change the language for Button VB.Net
magicdl96
magicdl96
hello everybody,
I built the Add-in whose buttons are in the English language. And I want to create a new Button to change the language in my Add-Ins.
Anyone have any ideas to help me?
Thank you so much.
robertast
@magicdl96
Isn't it easier to rewrite Add-in in the right language?
magicdl96
I want to write a multilingual Add-In. And I can't rewrite every language.
HideoYamada
Are you using WinForms? Or WPF?
If you use WinForms, "Language" property of the base form changes the language.
It's an important that the text should be written in English when "Language" property is "(Default)".
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
HideoYamada
Language will be selected automatically and it is depending on Inventor's language. (Not Windows's)
Freeradical
 Hideo Yamada
magicdl96
Yes. I know. But i want change language of button on ribbon.
HideoYamada
Create a string in Resources.resx and Resouces.<language>.resx and replace the hard-coded texts in your code to "Properties.Resources.<string name in resources.resx>".
// This code is in C#.
// Change the code from:
// var CommandName = "My command name";
// To:
var CommandName = Properties.Resouces.MyCommandName;
// "MyCommandName" must exist in Resouces.resx.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
