Change sketch line color
Is it possible to change the line color in a planar sketch using ilogic as shown in the picture? Here is the code i have so far:
Dim osketch As PlanarSketch
osketch = ThisApplication.ActiveEditObject
For Each oentity In osketch.SketchLines
oentity.Layer.color.SetColor(100,100,100)
Next
Also how and in when do you use this command?
ThisApplication.CommandManager.ControlDefinitions.Item("SketchLineColorProperty").Execute2 (True)
Curtis_Waguespack
Hi @Anonymous
See if this recent thread helps:
https://forums.autodesk.com/t5/inventor-customization/having-trouble-setting-sketch-color-in-a-part/m-p/9284119#M105166
I hope this helps.
Curtis
No. This only changes the sketch color not the exact sketchline color......
JelteDeJong
does this help?
Dim red As Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
Dim osketch As PlanarSketch = ThisApplication.ActiveEditObject
For Each oentity As SketchLine In osketch.SketchLines
    oentity.OverrideColor = red
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Yes! This is exactly what i was looking for....:)
