Change Sheet Metal Unfold Rule with ILogic
philip1009
Advisor Advisor
philip1009
I have a sheet metal part that has set Sheet Metal Rules and Unfold Rules in Sheet Metal Defaults.  And I have the working code to change the active sheet metal rule via "SheetMetal.SetActiveStyle" working just fine.
SyntaxEditor Code Snippet
If SYSTEM="AC-10C" Or
SYSTEM="AC-20C-A" Or
SYSTEM="AC-20C-B" Or
SYSTEM="AC-20C-C" Then
SheetMetal.SetActiveStyle("4MM COMPOSITE")
ElseIf SYSTEM="AC-10P-A" Or
SYSTEM="AC-10P-B" Or
SYSTEM="AC-10P-C" Or
SYSTEM="AC-20P-A" Or
SYSTEM="AC-20P-B" Or
SYSTEM="AC-20P-C" Then
SheetMetal.SetActiveStyle(".125 ALUMINUM")
ElseIf SYSTEM="AC-10ST-A" Or
SYSTEM="AC-10ST-B" Or
SYSTEM="AC-10ST-C" Or
SYSTEM="AC-20ST-A" Or
SYSTEM="AC-20ST-B" Or
SYSTEM="AC-20ST-C" Then
SheetMetal.SetActiveStyle("14 GA. STEEL")
But I can't find the code to change the Unfold Rule along with it.  Each Sheet Metal Rule has its own matching Unfold Rule with its own custom equations.
I know you can set the Unfold Rule under the Sheet tab of the Sheet Metal Rule, but how do you automatically make that rule the default unfold rule in the various part features.
Thanks in advance.
This is Inventor Professional 2017 btw.
HermJan.Otterman
Hello Philip
what do you mean by "various part features"
in your sheetmetal template you can setup your defaults, after creating the Sheetmetal rule and unfold rule.
if you would like to have different unfold rule, create more sheetmetalrules with matching unfold rules.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
philip1009
Hi Herm, I know you can set a default unfold rule in each sheet metal style.  But changing the sheet metal style doesn't change the unfold rule with it.  What I mean by various features is flanges, contour flanges, etc.  They don't take the unfold rule in the selected sheet metal style, they take the unfold rule selected from the drop-down in the sheet metal defaults.
Basically, If I want .125 ALUMINUM that already has the corresponding unfold rule in the style, it doesn't automatically change the default unfold rule in the flanges, etc. to.125 ALUMINUM, it always uses the unfold rule selected outside the sheet metal style.
I attached some pictures to try to show you what's going on.
Thanks for your quick reply.
HermJan.Otterman
Hello Philip,
if you set it up correctly, the sheetmetal unfold will change with the selection of the Sheetmetal rule.
I made a screencast:  http://autode.sk/2mQTk7C
at first, the unfold and material will not change.
after changing the settings in my Sheetmetal template, they will change with the sheetmetal rule
Herm Jan
