Change scale and position of drawing view
adhil.pa.789
adhil.pa.789
Changing position and scale is not working for me.  Anyone know this?
Sub IdwPart()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
strLocation = ThisApplication.FileOptions.TemplatesPath
Set oDrgDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, strLocation & "A3.idw")
Dim oSheet As Sheet
Set oSheet = oDrgDoc.Sheets.Item(1)
Dim oPoint1, oPoint2 As Point2d
Set oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
Set oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(10, -5)
Dim oBaseView, top As DrawingView
Set oBaseView = oSheet.DrawingViews.AddBaseView(oDoc, oPoint1, 1, kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Set top = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
'scale value
Dim  scle As Double
scle = (29.7 - 17) / (oBaseView.Height + top.Height)
Dim a, s As String
a = ":1"
s = scle & a
Select Case scle
  Case Is > 1.5
    oSheet.Size = kA4DrawingSheetSize
   oBaseView.ScaleString = s
   oBaseView.Position.X = 15
  Case 0.4 To 1.5
  oSheet.Size = kA3DrawingSheetSize
   oBaseView.Position.X = 21
  End Select
End Sub
Andrii_Humeniuk
Hi @adhil.pa.789 . Changing the scale and position worked for me only when I took them outside the "Select Case", maybe your "scle" parameter does not fall within the selection.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
adhil.pa.789
Sub IdwPart()
Dim oSheet As Sheet
'scale value
Dim d1, d2, d3, scle, s1, s2, s3 As Double
Dim a, s As String
a = ":1"
s = scle & a
Dim oCoords(0 To 1) As Double
Dim pnt As Point2d
Dim oView1 As DrawingView
Set oView1 = oSheet.DrawingViews.Item(1)
Select Case scle
  Case Is > 1.5
     oCoords(0) = 15
     oCoords(1) = 15
    Set pnt = ThisApplication.TransientGeometry.CreatePoint2d(oCoords(0), oCoords(1))
    oView1.Position = pnt
  Case 0.4 To 1.5
     oCoords(0) = 21
     oCoords(1) = 15
  End Select
End Sub
Thanks for reply @Andrii_Humeniuk
I got it
