Change properties of appearance by code
b.graaf
b.graaf
I have searched but not found an answer.
Is it possible to change the properties of a document appearance by code (iLogic, VB or perhaps C#)?
So I do not mean to change the color of the part itself, but color, bump, textures and so on of an existing appearance in the appearance library (document appearances)
I have found a small peace of code, to get an appearance, which can be found within my Inventor document:
Dim doc As Document
doc = ThisApplication.ActiveDocument
Dim appearance As Asset
appearance = doc.Assets.Item("RAL 5015 Sky blue")
But how can I change the properties of this appearance, like color, reflectivity, transparancy, etc.....
HermJan.Otterman
Hello B.
do you mean this:
https://forums.autodesk.com/t5/inventor-forum/access-material-property-fields-via-iproperty-expressi...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
b.graaf
Hello Hermjan,
Tnx for your reply.
What I like to achieve, is to change some vaules of document appearances. These appearances do not need to have been used in the part, I just want to itterate through the appearances and change some values like color and I would like to clear the image and to uncheck for example the bump and tint options.
See also attachment.
HermJan.Otterman
Hello B.
With this iLogic rule you will go through the properties
        Dim oPartDoc As Inventor.PartDocument = ThisApplication.ActiveDocument
        Dim oAppearanceAssets As AssetsEnumerator = oPartDoc.AppearanceAssets
        Dim oAsset As Asset
        'loop trough the part appearences
        For Each oAsset In oAppearanceAssets
            'Loop through the assetsvalues, that you see in the appearance dialogbox
            Dim oAssetValue As AssetValue
            For Each oAssetValue In oAsset
                MsgBox(oAssetValue.DisplayName,,"Asset Value")
                'here you can do something with the values
                'On Error Resume Next
                'MsgBox(oAssetValue.value)
            Next
        Next
Herm Jan
b.graaf
Hello HermJan,
Tnx, with this I managed what I tried to do.
I have used it not in iLogic, but in a simple VB addin.
I managed to accomplish my goal, to change some values of several appearances within all the parts in an assembly!
This is part of the code I have used:
                'Uncheck bump
                Try
                    If oAssetValue.DisplayName = "Tint" Then
                        Dim booleanValue As BooleanAssetValue
                        booleanValue = oAssetValue
                        booleanValue.Value = False
                Catch
                    'Some error handling
                End Try
                'Uncheck Tint
                Try
                    If oAssetValue.DisplayName = "Bump" Then
                        Dim colorAssetValue As ColorAssetValue
                        colorAssetValue = oAssetValue
                        colorAssetValue.HasConnectedTexture = False
                Catch
                End Try
        Next
Next
RoyWickrama_RWEI
Hi HermJan.Otterman
Thanks a lot. Your code was useful to fix one of my rules.
https://forums.autodesk.com/t5/inventor-customization/to-retrieve-appearances-from-the-current-appea...
Roy Wickrama
