change position of representation with shortcut
skyngu
skyngu
hi all
is there any way that I can change position of represenations with shortcut on keyboard? I use mouse to select each position now. thanks
inventor 2013 sp2 64bit with window 7
Autodesk Inventor Professional 2019
adam.nagy
Autodesk Support
Autodesk Support
You mean you want to switch to a specific positional representation inside the assembly through a shortcut?
If so, you could create a VBA macro and assing a shortcut to it in the Customize dialog:
Sub ChangeActiveDesignViewRepresentation()
    Dim doc As AssemblyDocument
    Set doc = ThisApplication.ActiveDocument
    Dim rm As RepresentationsManager
    Set rm = doc.ComponentDefinition.RepresentationsManager
    Call rm.PositionalRepresentations("Position1").Activate
End Sub
Cheers,
Adam Nagy
Autodesk Platform Services
skyngu
no, i meant a shortcut to change position from one to another.
for example, there are poisiont1, position2, position3. when i use "crtl+n", it changes from position1 to position2, then to position3.
thanks.
adam.nagy
Autodesk Support
Autodesk Support
You could do something like this then:
Sub ActivateNextPositionalRepresentation()
    Dim prs As PositionalRepresentations
    Set prs = rm.PositionalRepresentations
    Dim index As Integer
    For index = 1 To prs.Count
        If rm.ActivePositionalRepresentation Is prs(index) Then Exit For
    Next
    index = index Mod prs.Count + 1
    Call prs(index).Activate
End Sub
Cheers,
Adam Nagy
jR0sal3s
are you able to do some variation of this code so it works with specific posrep of a sub assembly..?
