Change part to (bleu) clear
Message 1 of 12
In an assy I frequently put parts as a clear color like blue (clear).
Anyone having a macro to do that just by selecting the parts and then click on the macro or so?
Replies (11)
Message 2 of 12
Something like the following? (Select the occurrences in the assembly to
change the color of, and run the macro)...
Sub OccurrenceColor()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oOccurrences As ObjectCollection
Set oOccurrences =
ThisApplication.TransientObjects.CreateObjectCollection
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.SelectSet
oOccurrences.Add oOcc
Next
Dim oRS As RenderStyle
Set oRS = oDoc.RenderStyles.Item("Blue (Clear)")
For Each oOcc In oOccurrences
Call oOcc.SetRenderStyle(kOverrideRenderStyle, oRS)
Next
End Sub
wrote in message news:5245890@discussion.autodesk.com...
on the macro or so?
Message 3 of 12
It probably doesn't work in IV10 no? I get the 438 error.
Object doesn't support this property or methode.
I will check later in IV11, thanks already for the quick reply!
Message 4 of 12
Ah, yes ,that code will only work in R11. For R10, try replacing the
following line of code:
with
oOcc.RenderStyle = oRS
Sanjay-
wrote in message news:5247083@discussion.autodesk.com...
Message 5 of 12
YES! that did it!
I'll make it more advanced now by adding a form where I can select the style. Something like 2 clear colors and the as material for instance.
This makes my work again a little faster, so I can spend more time at the cofee machine!
Message 6 of 12
Ok,
I added a form and some colors to it.
Now the strange thing is I can add as much colors as I whant. But "As Material" never works! It debugs!
What's the reason?
Private Sub CmdChange_Click()
Set oOccurrences = ThisApplication.TransientObjects.CreateObjectCollection
Next
If opbBlueClear = True Then
Else
If opbGreenClear = True Then
Set oRS = oDoc.RenderStyles.Item("Green (Clear)")
Else
Set oRS = oDoc.RenderStyles.Item("As Material")
Next
End Sub
Message was edited by: Stefaan Boel Message was edited by: Stefaan Boel
Message 7 of 12
Change to
Set oOcc.SetRenderStyle(kPartRenderStyle)
Wayne
Message 8 of 12
Try this.
< Set oRS = oDoc.RenderStyles.Item("As Material")
Change to
Set oRS = oOcc.SetRenderStyle(kPartRenderStyle)
Wayne
Message 9 of 12
The equivalent to this in R10 is:
Set oOcc.RenderStyle = Nothing
When you set the color of an occurrence you're overriding the color defined
in the part. This is removing the override so it goes back to the part
color.
Brian Ekins
Autodesk Inventor API
wrote in message news:5250314@discussion.autodesk.com...
Try this.
Change to
Wayne
Message 10 of 12
Sorry wayne, still using IV10, thx anyway!
Brian,
I had to remove the Set to make it work.
So it becomes:
Next
If I keep set, it doesn't work
regards,
Stefaan
Message 11 of 12
The use of the Set keyword is somewhat inconcistent. The general rule is
whenever you are assigning something to an object you need to use Set.
That's one of the nice features of VB.Net is that Set is no longer used.
Brian Ekins
Message 12 of 12
Brian,
Could you give any info on this topic:
http://discussion.autodesk.com/thread.jspa?messageID=5251777⋁
Wayne
