Change part Material in vb.net addin
j.lindingerSNBEM
Observer Observer
j.lindingerSNBEM
Observer
Observer
Dear all,
i am currently working on an Add-In to give the user an enhanced GUI to pick the material for an inventor part.
I had a similar solution working in VBA.
It is no problem to read the active material in a listview and attach the material asset object to the tag.
When doubleclicking an Item in the Listview i like to take the material object from tag and assign to my part document.
This is the code snippet to assign material from listview "lvMaterial":
        Dim oDoc As Inventor.PartDocument
        If g_inventorApplication.ActiveDocumentType = DocumentTypeEnum.kPartDocumentObject Then
            oDoc = g_inventorApplication.ActiveDocument
        Else
            MsgBox("Document type is not kPartDocumentObject")
            Exit Sub
        Dim oMaterial As Inventor.MaterialAsset
        oMaterial = lvMaterial.SelectedItems(0).Tag
        oDoc.ComponentDefinition.Material = oMaterial
When Executing the code i get an error in the compiler telling me "Interface not supported, HRESULT: 0x80004002 (E_NOINTERFACE)".
I assume the Problem is to assign a MaterialAsset Object to a Material Object.
I know in VBA there was the Option to define a variable of type Material, but in VB.Net I can only find MaterialAsset.
Do you have any hint for me how this could work? in the SDK Documentation there is nothing documented on how to assign a material. I can only find how to read out all the materials, but that was the easiest thing.
I hope for your support, thanks in advance
Julian
JhoelForshav
Hi @j.lindingerSNBEM
You could try using oDoc.ActiveMaterial which is of type MaterialAsset:
Else
	Exit Sub
oDoc.ActiveMaterial = oMaterial
oDoc.ComponentDefinition.Material is of typr Inventor.Material and that object type seems to be exposed by the API but not documented...
j.lindingerSNBEM
Observer
Observer
Hi Jhoel,
Thank you very much for your support, this solved my problem. I tried serveral things one the one hand with iteration of assets by numbering or asset in Listview.Tag and on the other hand with ActiveMaterial Property and ComponentDefinition.Material but I did not manage to use Object from Tag with ActiveMaterial.
Now with your suggested code it works!
Best regards,
Julian
