Change Part/Assy Iproperties from Within Drawing
morrisangelo
morrisangelo
Looking to change part or assembly iproperties from within a drawing without having to open the part or assembly.  Does anyone have a code to do this?
kelly.young
Autodesk Support
Autodesk Support
Hello @morrisangelo you can RMB on the dimension from the drawing and select Edit Model Dimension on Parts.
From an Assembly in a drawing, getting to the Part dimensions and then being able to change them without opening the part, not sure how to do that without custom iLogic code to link the parameters into a iLogic Form.
Will move thread to Inventor Customization Forum to see if there is a better workaround.
Please select the Accept as Solution button if a post solves your issue or answers your question.
