change paper size name
GSK2019
GSK2019
I am writing a code. And so far everything works besides when you chose: "A0 Custom". That in the drawing paper size it says: "Custom Size (mm)"
Is it possible that it will say: "A0xl"
Sub Main()
	Dim oSheetFormat As New ArrayList
	oSheetFormat.Add("A0 Custom")
	oSheetFormat.Add("A0 Liggend")
	oSheetFormat.Add("A0 Staand")
	oSheetFormat.Add("A1 Liggend")
	oSheetFormat.Add("A1 Staand")
	oSheetFormat.Add("A2 Liggend")
	oSheetFormat.Add("A2 Staand")
	oSheetFormat.Add("A3 Liggend")
	oSheetFormat.Add("A3 Staand")
	oSheetFormat.Add("A4 Liggend")
	oSheetFormat.Add("A4 Staand")
oSheetFormatIP = InputListBox("Sheet Format", oSheetFormat, oSheetFormat(0))
If oSheetFormatIP = oSheetFormat(0) Then Sheet_A0Xl_Custom(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(1) Then Sheet_A0_Liggend(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(2) Then Sheet_A0_Staand(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(3) Then Sheet_A1_Liggend(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(4) Then Sheet_A1_Staand(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(5) Then Sheet_A2_Liggend(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(6) Then Sheet_A2_Staand(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(7) Then Sheet_A3_Liggend(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(8) Then Sheet_A3_Staand(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(9) Then Sheet_A4_Liggend(oSheetFormatIP)
If oSheetFormatIP = oSheetFormat(10) Then Sheet_A4_Staand(oSheetFormatIP)
End Sub
Sub Sheet_A0Xl_Custom(x)
Lengte = InputBox("Lengte", "Lengte", "Default Entry")
ActiveSheet.ChangeSize(1188, Lengte, moveBorderItems :=True)
End Sub
Sub Sheet_A0_Liggend(x)
	ThisApplication.ActiveDocument.ActiveSheet.Orientation = Inventor.PageOrientationTypeEnum.kLandscapePageOrientation
	ActiveSheet.ChangeSize("A0", moveBorderItems :=True)
End Sub
Sub Sheet_A0_Staand(x)
	ThisApplication.ActiveDocument.ActiveSheet.Orientation = Inventor.PageOrientationTypeEnum.kPortraitPageOrientation
End Sub
Sub Sheet_A1_Liggend(x)
	ActiveSheet.ChangeSize("A1", moveBorderItems :=True)
End Sub
Sub Sheet_A1_Staand(x)
End Sub
Sub Sheet_A2_Liggend(x)
	ActiveSheet.ChangeSize("A2", moveBorderItems :=True)
End Sub
Sub Sheet_A2_Staand(x)
End Sub
Sub Sheet_A3_Liggend(x)
	ActiveSheet.ChangeSize("A3", moveBorderItems :=True)
End Sub
Sub Sheet_A3_Staand(x)
End Sub
Sub Sheet_A4_Liggend(x)
	ActiveSheet.ChangeSize("A4", moveBorderItems :=True)
End Sub
Sub Sheet_A4_Staand(x)
End Sub
Michael.Navara
This is not possible, because this names are stored internally in Inventor.
If you want to display your custom sheet name, you need to change the sheet property size to prompt string and set them using code.
GeertvanderHeide
think you have to edit the titleblock to change it everytime you set the sheet size
dim oDoc as DrawingDocument = ThisDoc.Document
dim oTB as TitleBlock = oDoc.ActiveSheet.TitleBlock
dim oTextBox as TextBox
for a =1 to oTB.definition.sketch.TextBoxes.count
   if oTextBox.Text = "<Sheet Size>" then
     logger.info(a)
     exit for
   end if
next
dim SheetSizeBox as TextBox = oTB.definition.sketch.TextBoxes.item(a)
SheetSizeBox.Text = "<Sheet Size>"
SheetSizeBox.Text = "A0 x L"
the first part is just to find the right textbox you want. once you have that one you should be able to call it always with the same number. else build in a safety to check the value in the textbox.
other thing might be that when you write "<Sheet Size>" to the textbox the link to the normal sheet size can't be found, but that should be tested.
