Change Home View using iLogic code
Message 1 of 20
I have a model which can be placed vertical or horizontal. I have made user parameters as Horizontal & Vertical. With these parameters i need to link and change the home view as per the selected option. For Vertical Z axis should face upwards and for Horizontal Y axis should face upwards.
Can anyone suggest me a code which can change and set the "Set Current View as Home"? Please see the attach picture for reference.
Replies (19)
Message 2 of 20
Vladimir.Ananyev
Hope this topic could help you
http://forums.autodesk.com/t5/inventor-customization/viewcube-rotation-through-api/m-p/5175541#M5106...
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 20
@Vladimir.Ananyev Well this command works pretty well for rotating my active view, this solves my half question. The remaining half question is how to make this new changed active view as my home view or you can say "Set Current View As Home" using iLogic code. Thanks for reply.
Message 4 of 20
Vladimir.Ananyev
You may try the following rule:
'Dim name As String = "AppViewCubeViewHomeFixedCmd"
Dim name As String = "AppViewCubeViewHomeFloatingCmd"
Dim oDef As ButtonDefinition = ThisApplication.CommandManager _
		.ControlDefinitions.Item(name)
oDef.Execute
How to get the full list of the Inventor command names is described here:
Running Commands Using the API
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Vladimir Ananyev
Message 5 of 20
Yes that works for me, can you please suggest me enum value for FrontRightISO view?
Message 6 of 20
Vladimir.Ananyev
I’ve printed a list of all of the commands available in the Inventor 2015 (using the code provided by the article mentioned earlier).  Here are commands that are ready to use:
AppViewCubeCmd
AppViewCubeHomeCmd
AppViewCubeOrthographicCmd
AppViewCubePerspectiveCmd
AppViewCubePerspectiveOrthoCmd
AppViewCubePropertiesCmd
AppViewCubeViewFrontCmd
AppViewCubeViewLockCurrentSelectionCmd
AppViewCubeViewResetToFrontCmd
AppViewCubeViewTopCmd
View.Camera.ViewOrientationType property cpould be also useful.  See Inventor API Help for the ViewOrientationTypeEnum values available.
cheers,
Vladimir Ananyev
Message 7 of 20
I have found the following enum values but not able to find the FrontRightIso enum. Can you please suggest me for it?
'list of view enums:
' kTopViewOrientation = 10754
' kRightViewOrientation = 10755
' kBackViewOrientation = 10756
' kBottomViewOrientation = 10757
' kLeftViewOrientation = 10758
' kIsoTopRightViewOrientation = 10759
' kIsoTopLeftViewOrientation = 10760
' kIsoBottomRightViewOrientation = 10761
' kIsoBottomLeftViewOrientation = 10762
' kFrontViewOrientation = 10764
Message 8 of 20
Vladimir.Ananyev
ViewOrientationTypeEnum Enumerator
kIsoTopRightViewOrientation 10759 Isometric -- Top Right View.
Does it work for you?
Vladimir Ananyev
Message 9 of 20
10759 is for TopRightViewOrientation but i need for FrontRightViewOrientation.
Message 10 of 20
Vladimir.Ananyev
All predefined orientations are listed in the ViewOrientationTypeEnum enumerator.
Any other orientations you may get programmatically using Camera object functionality.
Vladimir Ananyev
Message 11 of 20
Actually i dont know how to get the view ISO view.PNGFrontRightISO view using programmatically using Camera object functionality.
Message 12 of 20
MegaJerk
Depending on the version of Inventor that you're using, I actually would shy away from using the Camera function to change views, for now, unless you know that your code won't be used by someone who uses the Perspective View type instead of Orthographic.
Why?
Because I think that there is currently a bug with how Inventor (2015 and probably up I'd imagine) handles the math to change the Perspective Angle when the view is set to Perspective = True, and there are no visible occurrences on the screen. It essentially creates an overflow bug that will force a crash or create an instability, which is never fun.
Recently I have reworked my view code to:
Sub FitStageToScreen ()
 'Dim cam As Inventor.Camera
 'cam = ThisApplication.ActiveView.Camera
 'cam.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopRightViewOrientation
 'cam.Apply()
 'cam.Fit()
 'cam.ApplyWithoutTransition()
  Call ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomAllCmd").Execute
  Call ThisApplication.ActiveView.GoHome
End Sub
I believe that this should accomplish what you are wanting to do.
However, for those of you who would like to have a little fun crashing / messing with your session of inventor, feel free to use to use the following code to do so! (*** This actually should not cause any problems in 2012, but SHOULD cause a problem in 2015 and up. I'm not sure when it was introduced into Inventor, so if you have a version that is different from the ones listed above, it would actually be nice to get some feedback to find out if it's causing bad things to happen or not!)
Imports Inventor.ViewOrientationTypeEnum
If ThisApplication.ActiveDocument.DocumentType _
<> kAssemblyDocumentObject Then
    MessageBox.Show ("Run from an Assembly!!!")
    Return
' Set the current assembly to the active document
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
' Set the document's Assembly Component Definition
Dim oCompDef As AssemblyComponentDefinition
oCompDef = oDoc.ComponentDefinition
' Setting the Reps Manager
Dim oRepManager As RepresentationsManager
oRepManager = oCompDef.RepresentationsManager
' This used to test to see if you were on a 'Locked'
' ViewRep, but that doesn't work because for whatever reason,
' If you're on the Master View Rep, it is ***NOT*** flagged
' as being locked through the ActiveDesignViewRepresentation
' , even though it is locked if you were to look at the Design View
' directly through the Items collection.
' This might be another bug.
If oRepManager.ActiveDesignViewRepresentation.Name <> "View1" Then
	Try
		oRepManager.DesignViewRepresentations.Item("View1").Activate
	Catch
		oRepManager.DesignViewRepresentations.Add("View1")
	Finally
	End Try
' Let's set our oViewRep to the Active Design View
Dim oViewRep As DesignViewRepresentation
oViewRep = oRepManager.ActiveDesignViewRepresentation
' Setting the DesignViewReps
Dim oViewReps As DesignViewRepresentations
oViewReps = oRepManager.DesignViewRepresentations
' Getting all of the Components from the assembly
Dim oCompOccs As ComponentOccurrences
oCompOccs = oCompDef.Occurrences
' Setting an empty ComponentOccurrence container
Dim oCompOcc As ComponentOccurrence
' Change the view of ALL Components to Invisible
' The Perspective / Camera error will only occure
' if there are no visible Components.
For Each oCompOcc In oCompOccs
    oCompOcc.Visible = False
Next
' Let's get the Camera from the Active View Rep
Dim oCam As Camera
oCam = ThisApplication.ActiveView.Camera
' If your set for Ortho, we'll change it to Perspective.
' If you're already set to Perspective, this doesn't
' really do anything.
oCam.Perspective = True
oCam.Apply
' NO matter, while on Perspective, and
' with no parts visible, once you change the -
' ViewOrientationType to any valid enum, the
' PerspectiveAngle Is changed to a value outside
' of the Type Bounds For a Double.
oCam.ViewOrientationType = kIsoTopRightViewOrientation
oCam.Fit()
Call oCam.Apply()
' Typically doing the above will crash you, however
' occasionally it will not. Adding a new View Rep
' 'which will change the active camera' will push it over
' the edge, but even sometimes this is just as spotty.
Dim oNewViewRep As DesignViewRepresentation
oNewViewRep = oViewReps.Add("Crash")
oNewViewRep.Activate
oNewViewRep.Delete
Dim oOriginalCamera As Camera
oOriginalCamera = oViewRep.Camera
' Just in case you haven't crashed yet
' I'm throwing this in there because it where I will
' absolutely run into problems. Trying to turn the Occurrences
' back to visible will make bad things happen!
    oCompOcc.Visible = True
Next
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 13 of 20
If you are saying to get programmatically using Camera object functionality. Then how to do so?
Please refer 2 images in my very first question for your reference.
So my question is 10759=TopRightViewOrientation= Horizontal and ?=FrontRightViewOrientation = Vertical
? is the Enum for view which i cant find.
Message 14 of 20
Message 15 of 20
MegaJerk
Here is a complete list of the Inventor.ViewOrientationTypeEnum Enumerator
Public Enum ViewOrientationTypeEnum
  kDefaultViewOrientation = 10753
  kArbitraryViewOrientation = 10763
  kCurrentViewOrientation = 10765
  kSavedCameraViewOrientation = 10766
  kFlatPivotRightViewOrientation = 10767
  kFlatPivotLeftViewOrientation = 10768
  kFlatPivot180ViewOrientation = 10769
  kFlatBacksideViewOrientation = 10770
  kFlatBacksidePivotRightViewOrientation = 10771
  kFlatBacksidePivotLeftViewOrientation = 10772
  kFlatBacksidePivot180ViewOrientation = 10773
End Enum
GitHub
Message 16 of 20
Enum below kFrontViewOrientation = 10764 are not working with me. It is showing error message as
"Error in rule: View Cube Rule, in document: Pressure Vessel AssemblyUpload.iam
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
and kDefaultViewOrientation = 10753 is also showing error.
Message 17 of 20
MegaJerk
Could you post the code that you are using apply these actions?
It would be extremely helpful in evaluating your problem with more clarity.
GitHub
Message 18 of 20
I know that this is an old thread but i want to share this to them who are figuring out how to get that particular view. The view is also known as "Home View" and can be set by pressing F6. Ilogic code for that is this simple and it's posted originally by MegaJerk:
SyntaxEditor Code Snippet
 -Mika
Message 19 of 20
S_May
Hi @Anonymous,
This is not a code but that could help you synonymous AUTODESK APP
greetings
S_May
Message 20 of 20
S_May
HI @Anonymous,
Zoom home & browser node rename & browser from a to z sort, helps you the code?
greetings
S_May
'-----start of ilogic-----
'sort components in the browser
ThisApplication.CommandManager.ControlDefinitions.Item _
("AssemblyBonusTools_AlphaSortComponentsCmd").Execute
'set a reference to the document
Dim oDoc As Document
'Set a reference to the top node of the active browser
Dim oTopNode As BrowserNode
oTopNode = oDoc.BrowserPanes.ActivePane.TopNode
Dim oNode As BrowserNode
For Each oNode In oTopNode.BrowserNodes
' If the node is visible and expanded, collapse it.
If oNode.Visible = True And oNode.Expanded = True Then
oNode.Expanded = False
Next
'Return view to Home view
("AppViewCubeHomeCmd").Execute
'zoom all
ThisApplication.ActiveView.Fit
'-----end of ilogic-----
