Message 1 of 13
Change feature color in a component, from an assembly
I'm trying to change the color of two features (EXT FINE & INT FINE) within a component (GBG) .ipt. From the assembly level. I'm not sure if its model states that are messing me up or if its just the code itself.
Any help would be much appreciated!
Dim EXTCOLOR As String = Parameter("exterior_color") Dim INTCOLOR As String = Parameter("interior_color") MyBAR.MemberEditScope = MemberEditScopeEnum.kEditAllMembers Select Case GRL_TYPE Case "FL" Select Case EXTCOLOR Case "BLK" 'Black Feature.Color("GBG", "EXT FINE") = "Black" Case "CCBN" 'Cocoa Bean Feature.Color("GBG", "EXT FINE") = "Cocoa Bean" Case "DBRZ" 'Dark Bronze Feature.Color("GBG", "EXT FINE") = "Dark Bronze" Case "SND" 'Sandtone Feature.Color("GBG", "EXT FINE") = "Sandtone" Case "TT" 'Terratone Feature.Color("GBG", "EXT FINE") = "Terratone" Case "WHT" 'White Feature.Color("GBG", "EXT FINE") = "White" End Select Select Case INTCOLOR Case "BLK" 'Black Feature.Color("GBG", "INT FINE") = "Black" Case "DBRZ" 'Dark Bronze Feature.Color("GBG", "INT FINE") = "Dark Bronze" Case "SND" 'Sandtone Feature.Color("GBG", "INT FINE") = "Sandtone" Case "WHT" 'White Feature.Color("GBG", "INT FINE") = "White" End Select Case Else Feature.Color("GBG", "FDL") = "Aluminum - Flat" End Select MyBAR.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
