Change Face Color of Part With iLogic
insomnix
insomnix
I am working in a part file where I would like to change two faces to a specific color based on criteria. Below is a simplified version of the code and where it is failing. Both faces already have a color assigned and the code does find those two faces. However, when trying to call SetRenderStyle, the code errors and no faces are actually updated.
I am in Inventor 2018.
    Dim oPartDoc As PartDocument
    oPartDoc = ThisApplication.ActiveDocument
    ' Get all of the faces that have the "FaceColor" attribute.
    Dim oFaces As ObjectCollection
    oFaces = oPartDoc.AttributeManager.FindObjects( "com.autodesk.inventor.FaceAttributes", "FaceColor")
    ' Iterate through all faces that have colors and change.
    Dim oFace As Face
    Dim oStyle As RenderStyle
    For Each oFace In oFaces
		oStyle = oPartDoc.RenderStyles.Item("Beige")
		Call oFace.SetRenderStyle(kOverrideAppearance, oStyle)
    Next
R.Mabery
Hi insomnix,
Use Assets & the Appearance property instead.  Something like below:
Dim oAssets as Assets
oAssets = oPartDoc.Assets
Dim oAsset as Asset
oAsset = oAssets.Item("Bamboo")
     oFace.Appearance = oAsset
Next
Randy Mabery
Applications Expert
IMAGINiT Technologies
insomnix
Works great!
