Change Drive Part Model Stage using iLogic
frahaman7SKBG
frahaman7SKBG
Hi there,
I was wondering if anyone knows how to change a Drive Part's Model state using iLogic?
I would like to use iLogic to go into each individual Drive Part in an assembly and change the Model State of each part.  Currently, I only know how to do it manually, but I have over 50 parts and it can take lots of time.
JelteDeJong
I found the following code and I would expect that this would do the trick:
Dim doc As PartDocument = ThisDoc.Document
Dim comp As DerivedPartComponent = doc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1)
comp.Definition.ActiveModelState = "Master"
' and check if the "ActiveModelState" is changed.
MsgBox(comp.Definition.ActiveModelState)
But if I run this rule the ModelState will not change. Not sure what I do wrong or if this is a bug (@MjDeck  ).
Jelte de Jong
Blog: hjalte.nl - github.com
frahaman7SKBG
Thank you @JelteDeJong for your reply. Your snippet is definitely a start. It is able to grab the ActiveModelState.
Does anyone here know how to ChangeModelState?
MjDeck
You have to add an extra step. Here's sample code for a single part. This would have to be modified to make it run on multiple parts in an assembly.
Dim derivedDef = comp.Definition
Logger.Info("current model state = {0}", derivedDef.ActiveModelState)
Dim stateWanted = "Model State1"
If (derivedDef.ActiveModelState <> stateWanted) Then
	derivedDef.ActiveModelState = stateWanted
	comp.Definition = derivedDef ' apply the modified definition back to the DerivedPartComponent
Mike Deck
Software Developer
Autodesk, Inc.
frahaman7SKBG
Thank you @MjDeck. I was able to take your snippet and modify it to make it work.
