Change display information at message prompt
K.TRYFONIDIS
K.TRYFONIDIS
Hello everyone, new one here. First post.
I am trying to code some things for my company and i am using different forms to fill in iproperties.
The case is that i want to set 3 custom iproperties but in the display box i dont want to show the name of the variables
i would like to show a custom text defined by me.
This is my code
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim iprop(3) As String
iprop(1) = "DESCRIPTION"
iprop(2) = "NyfanID"
iprop(3) = "NyfanCurrentRev"
For k = 1 To 3
Dim prop(k) As String
    Try
        prop(k) = iProperties.Value("Custom", iprop(k))
    Catch
        'Assume error means not found
        customPropertySet.Add("", iprop(k))
        iProperties.Value("Custom", iprop(k)) = "null"
    End Try
Next
For j = 1 To 3
    Dim var(j) As String
    If iProperties.Value("Custom", iprop(j)) = "null" Then
        var(j) = InputBox("ΣΥΜΠΛΗΡΩΣΕ ΤΙΜΗ ΓΙΑ: " & iprop(j), "ΚΑΤΑΧΩΡΗΣΗ ΤΙΜΩΝ", "")
        iProperties.Value("Custom", iprop(j)) = var(j)
Next
And this is the message prompt:
Where instead of Description i would like to say something else like "Περιγραφή" but i want to keep the variable as
description.
is there any way to do this?  I am guessing i should "Break" the for command and do it somehow individually.
vpeuvion
Hi, you can try this with Dictionary(Of String,String).
Dim iprop As New Dictionary(Of String, String)
iprop.add("DESCRIPTION","YourName1")
iprop.add("NyfanID","YourName2")
iprop.add("NyfanCurrentRev","YourName3")
For Each Pair As KeyValuePair(Of String,String) In iprop
For k = 1 To iprop.count
    Try
        prop(k) = iProperties.Value("Custom", Pair.key)
    Catch
        customPropertySet.Add("", Pair.key)
        iProperties.Value("Custom", Pair.key) = "null"
    End Try
Next
For j = 1 To iprop.count
    If iProperties.Value("Custom", Pair.Key) = "null" Then
        var(j) = InputBox("ΣΥΜΠΛΗΡΩΣΕ ΤΙΜΗ ΓΙΑ: " & Pair.Value, "ΚΑΤΑΧΩΡΗΣΗ ΤΙΜΩΝ", "")
        iProperties.Value("Custom", Pair.key) = var(j)
Next
Next
Hope this can help you.
Vincent.
K.TRYFONIDIS
All i had to do is put bellow variable declaration this:
Dim msg(3) As String
msg(1) = "desired msg1"
msg(2) = "desired msg2"
msg(3) = "desired msg3"
WCrihfield
Hi @K.TRYFONIDIS.  Just so you are aware...when you create that Array of String using 'msg(3)', you are actually creating a 4 element array, not a 3 element array, because array's are zero based (first element is at zero position, not 1).  Since you are using For 1 To 3, this is not producing any problems, but if you used a For Each loop, the first element (msg(0)) would not contain a value, the way you coded it.
Wesley Crihfield
(Not an Autodesk Employee)
K.TRYFONIDIS
aha! very helpful to know! Thanks!
