Change Direction of existing Hole feature to Symmetric
J.VandeMerckt
J.VandeMerckt
Hi Everyone.
I need to change the the direction of a hole feature on multiple files.
I already have a code which allows a chosen Ilogic rule to run on all open files.
I just can't figure out how to change the direction of a hole to symmetric.
Googling and ChatGPT have not been able to solve it.
Can anyone help me out?
It's a part and the hole is called "Hole2"
Br
Justin
J-Camper
Try This:
Dim hf As HoleFeature = Feature.InventorFeature("Hole2")
If hf.ExtentType <> PartFeatureExtentEnum.kThroughAllExtent Then MessageBox.Show("""Symmetric Extent Direction"" Option only available on ""Through All"" hole features", "Debug") : Exit Sub
hf.SetThroughAllExtent(PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
harvey3ELEA
J-Camper, is there a way to change numerous holes (not limited to "Hole2" in line 1) to symmetric?
J-Camper
This should do all hole features in the part:
Dim pDoc As PartDocument = TryCast(ThisDoc.Document, PartDocument)
If pDoc Is Nothing Then Logger.Debug("Not Run in Part Document")
For Each hf As HoleFeature In pDoc.ComponentDefinition.Features.HoleFeatures
	If hf.ExtentType <> PartFeatureExtentEnum.kThroughAllExtent Then Logger.Trace("""Symmetric Extent Direction"" Option only available on ""Through All"" hole features") : Continue For
Next
J.VandeMerckt
Thanks Camper.
This exactly what I need.
Best regards
Justin
harvey3ELEA
Works great!  Thanks once again, J-Camper.
