Change description design features
DavidNysMetaal
DavidNysMetaal
like the subject explains, is it possible that you can change the description of the design features. Like when I place a bolted connection, the description in the BOM will be in english, can this description be changed in dutch (or any other language)?
Tony
Tony Goossens
Nys metaalwerken - Zonhoven (Belgium)
Inventor 2016 R3
Win7-x64
HP Z420 - Intel Xeon CPU E5-1650 @ 3.20GHz - 32GB RAM - Nvidia Quadro 4000
adam.nagy
Autodesk Support
Autodesk Support
Hi Tony,
It would be worth asking on the Product forum to check if Inventor has such capability:
http://forums.autodesk.com/t5/inventor-general-discussion/bd-p/78
Then on this forum you can check if / how it can be automated.
The naming of the forum might not be the best, but "Customization" means "API usage/programming"
Cheers,
Adam Nagy
Autodesk Platform Services
