CHANGE CUSTOMPROPERTY FORMAT IN ASSEMBLY ENVIROMENT
Innercia
Innercia
Hi, Im try to change g_l Properties for a frame placed, by assembly enviroment. I can Do it 1 by 1 parts, but i need to do n the general assembly.
Code for parts.
Sub MAIN()
	oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
	 oParameter = Parameter.Param("B_L")
        oParameter.ExposedAsProperty = True
        oParameter.IsKey = False
oParameter.CustomPropertyFormat.Precision = kZeroDecimalPlacePrecision
End Sub
code For assembly Doent works...
Sub MAIN()
	Dim oDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oDef.Occurrences
	Try
	oParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
RuleParametersOutput()
Catch
	MessageBox.Show(oOcc.Name & " does not have the parameter named as G_L")
	End Try
Next
InventorVb.DocumentUpdate
End Sub
A.Acheson
Hi @Innercia
Try out the below code. Check the "Make the new changes" lines to ensure you know what the new changes will be and also check you are targeting the right user parameter. It is currently set up for mm conversion.   I suggest to test on a small non production assembly to ensure you know what the changes will be.
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsm, "FG Updates") 'Make this a single transaction
For Each oDoc As Document In oAsm.AllReferencedDocuments 'Traverse all referenced documents
	If oDoc.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}") _' Frame generator component
		AndAlso oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject _ 'Part
		AndAlso oDoc.IsModifiable _'Not read only CC/Library document
		AndAlso Not oDoc.DocumentInterests.HasInterest("SkeletonDoc") _'(not reference skeleton)
		AndAlso oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0 'Exists in assembly (not derived base component)
			oDoc = TryCast(oDoc, PartDocument)
			Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
			Dim oUserParam As UserParameter = oCompDef.Parameters.UserParameters.Item("G_L")
			'Delete parameter expression and add back in to force an update to occur e.g precision to become active
			Dim currentValue As String = oUserParam.Expression
			oUserParam.Expression = "0"
			oUserParam.Expression = currentValue
			'Make the new changes
			oUserParam.Precision = 0
			oUserParam.ExposedAsProperty = True
        	oUserParam.IsKey = False
			oUserParam.CustomPropertyFormat.Precision = kZeroDecimalPlacePrecision
			oDoc.UnitsOfMeasure.LengthDisplayPrecision = 0
			oDoc.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMillimeterLengthUnits
			oCompDef.BOMQuantity.BaseUnits = "mm"
			oCompDef.BOMQuantity.SetBaseQuantity(BOMQuantityTypeEnum.kParameterBOMQuantity, oUserParam)
			'Read the new changes
			'Logger.Info("BASE QTY: " & oCompDef.BOMQuantity.GetEvaluatedBaseQuantity(BOMQuantityTypeEnum.kParameterBOMQuantity))
			'Logger.Info("UNIT QTY: " & oCompDef.BOMQuantity.UnitQuantity)
			'Customize part numbers
			'oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = oDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value
Next
oAsm.Update
oTransaction.End 'End the trasaction
Regards
Alan
