Change content center component based on parameter changes
david_campbell
david_campbell
How can I change size of the content center part in an assembly based on parameters using iLogic.
There is also the possibility that I would need to replace from content center. I have been unsuccessful in adapting previous examples to work as I need. attached is an example of a part I am tryig to change with parameters and the start of some iLogic. I am using inventor 2012
Inventor 2013
jletcher
LOL you have to pack and go your assembly just posting the iam does not send parts. iam is just a configurator that keeps information of parts and constraints but has no ipt's.
david_campbell
It shows how new I am to this.
Will this zip file be acceptable?
Inventor 2013
MjDeck
Here's a post about changing content center components:
http://forums.autodesk.com/t5/Autodesk-Inventor/Changing-C-C-component-Automation/td-p/2736623/highl...
There are no dedicated iLogic functions for content center operations. I recommend using the external rule in the file ContentCenterReplace.txt.  The latest version of that (from 03-20-2012) is posted on page 3 of the post above.
You can also find sample rules in other text files.
Mike Deck
Software Developer
Autodesk, Inc.
