Change Color of SolidBody
Message 1 of 15
How can I change the solid body appearance using ilogic?
Replies (14)
Message 2 of 15
Cadmanto
Welcome to the forum.
See if any of these links help you.
https://forums.autodesk.com/t5/inventor-forum/color-change-with-ilogic/td-p/3518666
https://forums.autodesk.com/t5/inventor-forum/ilogic-rule-to-change-body-appearance-of-solid-body/td...
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 15
Curtis_Waguespack
Hi @Anonymous,
The first link that Cadmanto provided works by changing the color of the feature, where one feature = one solid. That might or might not work for you.
But if you want to grab the solid body rather than the feature it gets a bit more involved. Attached is an example 2017 file that has some example rules that you can look at to see this in action.
And I'll add the code here as well in case you're using a version of Inventor older than 2017.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
change each body to a different color
Dim oDoc As PartDocument = ThisDoc.Document
oDef = oDoc.ComponentDefinition
'define appearance library by name
Dim assetLib As AssetLibrary
assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
sColor1 = "Red"
sColor2 = "Cyan"
'define colors to work with
Dim libAsset1 As Asset
libAsset1 = assetLib.AppearanceAssets.Item(sColor1)
Dim libAsset2 As Asset
libAsset2 = assetLib.AppearanceAssets.Item(sColor2)
' try to Copy the asset locally.
Try
	localAsset1 = libAsset1.CopyTo(oDoc)
Catch
'assume error means it's already local
	localAsset1 = oDoc.Assets(sColor1)
End Try
Try
	localAsset2 = libAsset1.CopyTo(oDoc)
Catch
	localAsset2 = oDoc.Assets(sColor2)
End Try
' change specific body to specific color
Dim oSB1 As SurfaceBody
oSB1 = oDef.SurfaceBodies(1)
oSB1.Appearance = localAsset1 'red
Dim oSB2 As SurfaceBody
oSB2 = oDef.SurfaceBodies(2)
oSB2.Appearance = localAsset2 'cyan
change all bodies to the same color
sColor1 = "Red"
Try
Catch
End Try
' set all solid bodies to the color
Dim oSB As SurfaceBody
For Each oSB In oDef.SurfaceBodies
		oSB.Appearance = localAsset1
Next
Message 4 of 15
jan.kubeczka
how to activate other color library by iLogic? (for example "RAL")
John
Message 5 of 15
mcgyvr
John
@jan.kubeczka Just change the "Autodesk Appearance Library" to the name of your library that contains the RAL colors..
Message 6 of 15
jan.kubeczka
By iLogic? How?
Message 7 of 15
BrianEkins
This VBA sample for the Inventor help chooses an appearance from a specific library and applies it to an occurrence in an assembly.  It's the same thing when applying an appearance to a body.
Brian Ekins
Message 8 of 15
dusan.naus.trz
I use change all bodies to the same color. I want to use As Part and it can not. How to do it?
sColor1 = "Red"
sColor1 = "As Part"
 it can not sColor1 = "As Part"
Message 9 of 15
dusan.naus.trz
Hi
Sorry, I see it in the attachment in ipt. All is OK
Message 10 of 15
dusan.naus.trz
I tried it ipt. Reset to Default. That's not good. The body color is not to be Default. It's got to be As Part. But that does not work. How do I return a body using iLogic with an As Part value?
Message 11 of 15
Curtis_Waguespack
Hi @dusan.naus.trz,
You can use something like this to set the color of all the bodies to "As Part"
' set all solid bodies to be "As Part"
	oSB.AppearanceSourceType = AppearanceSourceTypeEnum.kPartAppearance
Next
I hope this helps.
Curtis
Message 12 of 15
dusan.naus.trz
Curtis you are super. Great. It works. Thank you very much.
Message 13 of 15
petr_nohal
Hi Curtis
thank you, that's interesting. Please, I do not know if I can ask you? I have such a problem for a long time and I do not know how to do it. It is iLogic for features, change (1.all features to As body). And another change, but another code (2.All Face on As Feature). At work my colleagues paint the parts and I can not imagine it as a coloring book .-) Thank you if you have time. Or if anyone knows.
Message 14 of 15
Curtis_Waguespack
Hi @petr_nohal
Here is an ilogic example to set all bodies to "As Part", and features to "As Body", and faces "As Feature".
I hope this helps.
Curtis
oDoc =  ThisDoc.Document
For Each obj In oDef.AppearanceOverridesObjects
	If TypeOf obj Is SurfaceBody Then
        obj.AppearanceSourceType = _
    ElseIf TypeOf obj Is PartFeature Then
		AppearanceSourceTypeEnum.kBodyAppearance
    ElseIf TypeOf obj Is Face Then
		AppearanceSourceTypeEnum.kFeatureAppearance
Next
Message 15 of 15
petr_nohal
Hi, Curtis
Thank you very much. Yes it all works. Your blog is also very interesting. Thank you. Good luck.
