Change color in sub-assembly (override from top assembly)
Message 1 of 8
I have no idea on how to solve this problem.
What i want is this code:
Component.Color("023512-15:1") = Farve
to work on parts in a subassembly
my first intuision was this, but didn't work:
Component.Color("023512-18:1", "023512-15:1") = Farve
What should i do?
Replies (7)
Message 2 of 8
BrandonBG
Message 3 of 8
HermJan.Otterman
it should be:
Component.Color("023512-18:1", "023512-15:1") = "Farve"
(it should be written like a string so with the "")
and Farve should be an existing color
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 4 of 8
Rule Compile Errors in Farve, in 023512-00.iam
Error on Line 24 : Der er for mange argumenter til 'Public Property Color(componentName As Object) As String'.
i get this error
Also, The is a mutiValue list of colors so it should be wothout "", as far as i know.
Message 5 of 8
HermJan.Otterman
Hello Mikael,
look at my assembly.
the colors are cashed, so they exist.
look at the rules, these change the colors.
if it doesn't work for you, maybe you can share you assembly/part with the code you use, and I will look at it.
Herm Jan
Message 6 of 8
I also need the .ipt files, if i should open your .aim.
Anyhow, I think the problem occurs in the Pattern i have. the component i want to change color of is in an assembly in a pattern.
and good suggestions?
Message 7 of 8
HermJan.Otterman
Hello Mikael,
sorry, I attached the wrong file.
hope  this helps
Herm Jan
Message 8 of 8
Hello again HermJan.
Your assembly on have 2 parts, i have a subassembly indside my assembly, so the task is not the same 😕
i have also made a function which can the same as our assembly 🙂
also, my sub-assembly are in a pattern.
