change color from IPT to change to reference in IAM
S_May
Mentor Mentor
S_May
Hello together,
I need an ilogic the components on the part list reference will be red, the reference will be removed the components again as the material
component = reference = red
component = normal = color as material
Trigger is the changeover to reference or from reference back
The rule in the appendix can be almost :-(, can make the ilogic someone please
Here is the rule and the Video inventor-ilogic-farbe-referenzierter-bauteile-andern
' set a reference to the assembly component definintion.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check occurence BOM Structure and component definition BOM Structure
If oOccurrence.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Or _
oOccurrence.Definition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
'set color
Component.Color(oOccurrence.Name) = "Red"
Next
thx @GÖÖÖ and @kurtis
b_sharanraj
Hi @S_May
Try the below Code once 🙂
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
oAsmCompDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
For Each oOcc In oAssyDoc.ComponentDefinition.AppearanceOverridesObjects
If oOcc.BOMStructure <> kReferenceBOMStructure Then
oOcc.AppearanceSourceType = 100612
Next
Next
Regards
B.Sharan Raj
G.DeGheest
Question
Can the code be adapted to color referenced parts/subassembleys in the Main assembley
(to color subassembleys in subassembleys)
(to color parts in subassebleys, in the main assembley)
Thank you, for the practical iLogic rule
