Change all surface texture symbol style standard reference
Is it possible to change the Standard Reference for Surface Texture Style using iLogic for all texture symbols in drawing.
Regards
Steve
JhoelForshav
Hi @Anonymous
Try this ilogic rule in your drawing to change all standard references to "BS 308 - 1990" as in your image 🙂
For Each oSheet As Sheet In ThisDrawing.Document.Sheets
For Each oSymbol As SurfaceTextureSymbol In oSheet.SurfaceTextureSymbols
	oSymbol.Style.StandardReference = DraftingStandardEnum.kLegacyBSI_DraftingStandard 'BS 308 - 1990
Next
Next
Thanks Jhoel, that's exactly what I needed.
Regards
Steve
HI Jhoel,
Can this be done for an individually selected surface symbol?
Regards
Steve
Hi Jhoel,
Think I have done it by selecting symbol first, unless you know of another way of selecting symbols on the fly.
' Set a reference to the select set of the active document.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
' Find all selected occurrences and add them to an ObjectCollection.
Dim oSymbol As SurfaceTextureSymbol
Dim oSSet As SelectSet = oDoc.SelectSet
'Loop through all symbols
For Each oSymbol In oSSet
oSymbol.MaximumRoughness = ("0.8")
Next
JhoelForshav
Hi @Anonymous
You can run a rule like this and just dynamically click all the symbols you want to change. End the command by pressing escape-button.
While True
oSymbol  = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingSurfaceTextureSymbolFilter, "Pick surface texture symbols. End with Esc.")
If oSymbol Is Nothing Then Exit While
End While
Thanks Jhoel, your way feels more slick.
Regards
Steve
