Change active sheet
Change active sheet
AlbertoOutline
Change active sheet
AlbertoOutline
Hi everyone, I need to change active sheet by vba code in a drawing document.
How can I set DrawingDocument.ActiveSheet Property?
Thank in advance
AlbertoOutline
Solved! Smiley Very Happy
ThisApplication.ActiveDocument.Sheets(sheet number).Activate
_KarlH
Worth noting that Sheets also accepts the Sheet Name too, might make it easier to trace and troubleshoot.
Example below;
Sub Main()
	oDrawDoc = ThisApplication.ActiveDocument
	For Each oSheet In oDrawDoc.Sheets
		ThisApplication.ActiveDocument.Sheets(oSheet.Name).Activate
		Logger.Info("Sheet " + oSheet.Name + " is now active.")
		'Sub_routine_goes_here()
	Next
End Sub
