Center of gravity of a solid body
vpeuvion
vpeuvion
Hello everybody.
I try to access the values of the coordinates of the center of gravity of a solid body from ilogic without success. Does anyone have a lead?
Thank you.
Vincent.
WCrihfield
Hi @vpeuvion.  I worked on something like this before.  Check out this link to another related post helps you out.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/create-a-point-for-center-of-gravity-as...
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
vpeuvion
Hi WCrihfield .
Thank you for your reply.
That answers my question. Attached is the code derived from yours that I used to do my testing if that might help anyone in the future. The values correspond to those in the solid properties window.
Vincent.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kPartDocumentObject Then
	MsgBox("This rule only works for Part Documents.",vbOKOnly, "WRONG DOCUMENT TYPE")
	Exit Sub
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oWP As WorkPoint
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oBodies As SurfaceBodies = oPDef.SurfaceBodies
Dim oBody As SurfaceBody
Dim oCorner As Point, oD1, oD2, oD3 As Vector
Dim oC1, oC3, oCP As Point
Dim oL1 As LineSegment
Dim oHalfVector As Vector
oBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter," Select Body")
oBody.OrientedMinimumRangeBox.GetOrientedBoxData(oCorner, oD1, oD2, oD3)
oC1 = oCorner.Copy
oC1.TranslateBy(oD1)
oC3 = oCorner.Copy
oC3.TranslateBy(oD3)
oL1 = oTG.CreateLineSegment(oC1, oC3)
oCP = oL1.MidPoint.Copy
oHalfVector = oD2.Copy
oHalfVector.ScaleBy(.5)
oCP.TranslateBy(oHalfVector)
MessageBox.Show("X : " & Round(oCP.X*10,3) & " Y : " & Round(oCP.Y*10,3) & " Z : " & Round(oCP.Z*10,3))
