CC part check up code
Sprocket1077
Sprocket1077
Hi.
I do very basic iLogic.
I'm building a manifold with ''Ts'' and schedule pipes.
I want to check if the ''T'' in my assembly is really the one I selected with 3 text parameters such as ''Pump dia'', ''Pipe dia'' and ''schedule''.
So I want to write the part name of the ''T'' in a parameter.
I would like it to be created with a part of common text and adding my 3 parameters.
EX:
Reducing Outlet Tee''Pipe_dia'' - Schedule ''schedule'' ''Pump_dia''
and it should return
Reducing Outlet Tee14 - Schedule 40 10
It will be great if someone can help.
And I'm sure you can.
Sprocket1077
Hi.
Don't go further with this post.
I found my answer.
