Capturing click events and points during a native command (Leader)
NachoShaw
Advisor Advisor
NachoShaw
Hi
im curious. Is there a way to add a listener that can capture the click events which in turn can capture point locations during a native command? For easiness i'll reference the leader-
  • Invoke the native leader command from a code function that will allow to the listener to fire
  • continue with the native leader points being clicked and text being added
  • leader closes, listener stops
  • provide points clicked back to the user
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Frederick_Law
Typically the event listener will listen to all click events and filter out event from Leader Command.
To turn it on and off will need another event listener which catch Command event.
Michael.Navara
This s not possible, because only one instance of interaction events can be active at the time. Command DrawingLeaderTextCmd starts its own interaction events and your terminates.
You can play with the following code to get more information about interaction events behavior. Comment/uncomment lines in Sub Main for testing different scenarios.
Sub Main()
    interactionEvts = ThisApplication.CommandManager.CreateInteractionEvents()
    mouseEvts = interactionEvts.MouseEvents
    AddHandler mouseEvts.OnMouseClick, AddressOf OnMouseClick
    AddHandler interactionEvts.OnTerminate, AddressOf OnTerminate
    AddHandler interactionEvts.OnActivate, AddressOf OnActivate
    AddHandler interactionEvts.OnHelp, AddressOf OnHelp
    AddHandler interactionEvts.OnSuspend, AddressOf OnSuspend
    AddHandler interactionEvts.OnResume, AddressOf OnResume
    SharedVariable.Value("intEvents") = interactionEvts
    'interactionEvts.Start()
    Logger.Debug("Start command")
    'Start command terminates current interaction events
    'Waits until the command ends
    'interactionEvts.Parent.ControlDefinitions.Item("DrawingLeaderTextCmd").Execute2(true)
    'Continue execution
    'interactionEvts.Parent.ControlDefinitions.Item("DrawingLeaderTextCmd").Execute()
    Logger.Debug("End command")
    'Start interaction events terminates current command
End Sub
Dim interactionEvts As InteractionEvents
Dim mouseEvts As MouseEvents
Private Sub OnResume()
    LogEvent()
End Sub
Private Sub OnSuspend()
    LogEvent()
End Sub
Private Sub OnHelp(beforeorafter As EventTimingEnum, context As NameValueMap, ByRef handlingcode As HandlingCodeEnum)
    LogEvent()
End Sub
Private Sub OnActivate()
    LogEvent()
End Sub
Private Sub OnTerminate()
    LogEvent()
End Sub
Private Sub OnMouseClick(button As MouseButtonEnum, shiftKeys As ShiftStateEnum, modelPosition As Point, viewPosition As Point2d, view As Inventor.View)
    LogEvent()
End Sub
Private Sub LogEvent(<System.Runtime.CompilerServices.CallerMemberNameAttribute> Optional caller As String = "")
    Logger.Debug(caller)
End Sub
Michael.Navara
In the special case, you can obtain the points of created leader from its properties.
