Cant update sheet / View looks like raster view
m_baczewski
m_baczewski
Hi
My drawing rules work after changing the drawing view, and after my rule runs, one of the views looks rasterized and unfortunately, I can't do anything about it. Do you have any ideas why this is happening?
This appeared after adding such a rule:
Dim oDrawing As DrawingDocument
oDrawing = ThisApplication.ActiveDocument
oSheet = oDrawing.ActiveSheet
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim genDims = oSheet.DrawingDimensions.GeneralDimensions
Dim drawingViews As DrawingViews
drawingViews = oSheet.DrawingViews
Dim Arkusz_1 = ThisDrawing.Sheets.ItemByName("Arkusz:1")
Dim WIDOK2 = Arkusz_1.DrawingViews.ItemByName("WIDOK2")
Dim Krawedz4 = WIDOK2.GetIntent("Krawedz4")
Dim nameOfCurve As Integer = 5
Dim countOfDimensionsToDelete As Integer = Parameter("DC6_BLACHA.ipt.ilosc_w_szyku") -1
Dim itemToDelete As Integer = 29
If genDims.Count>28
	For i As Integer = 0 To countOfDimensionsToDelete
		If genDims.Count = 28
			Exit For
		genDims.Item(itemToDelete).Delete
	Next
If Parameter("DC6_BLACHA.ipt.ilosc_w_szyku") > 1
	For i As Integer = 0 To Parameter("DC6_BLACHA.ipt.ilosc_w_szyku")-2
		Krawedz = WIDOK2.GetIntent("Krawedz" + nameOfCurve.ToString)
		polozenieWymiaruWidok2_1 = oTG.CreatePoint2d((WIDOK2.Center.X)/10, (WIDOK2.Center.Y)/10 -3)
		Dim linDim1 = genDims.AddLinear(polozenieWymiaruWidok2_1, Krawedz4, Krawedz)
		nameOfCurve=nameOfCurve+1
	Next
For Each oDrawingDim In oSheet.DrawingDimensions
	If oDrawingDim.Attached = False Then
   		oDrawingDim.Delete
Next
iLogicVb.RunRule("AUTOMATYCZNE_USTAWIANIE_WYMIAROW")
InventorVb.DocumentUpdate()
'For Each oView In drawingViews
'		oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
'		oModelDoc.Update
'		'Update the sheet
'		oView.Parent.Update
'	Next
m_baczewski
After running the rule, the "UpToDate" status of the view is False. However, if I change the sheet and then come back to the same sheet, the issue disappears, and then the "UpToDate" status becomes True.
If i comment this part of code, it works very well.
'If genDims.Count>28
'	For i As Integer = 0 To countOfDimensionsToDelete
'		If genDims.Count = 28
'			Exit For
'		End If
'		genDims.Item(itemToDelete).Delete
'	Next
'End If
'For Each oDrawingDim In oSheet.DrawingDimensions
'	If oDrawingDim.Attached = False Then
'   		oDrawingDim.Delete
'	End If
'Next
