Cant get code to run in part if open visually boolean isnt True
jzcrouse
jzcrouse
So this code to run a rule in certain parts in a assembly works perfectly when the open part document boolean is True.
Dim oDoc As PartDocument = ThisApplication.Documents.Open(oFileName, True)
Its kind of annoying on large assemblies to have to watch every part be opened and closed.
Is there a reason why the code wont run my rule when the boolean is false or is inventor just not able to run the external rule if the part is not opened visually and I just have to deal with it?
Private Sub Main()
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
    ' Call the function that traverses the assembly
    Call Iterate(asmDoc.ComponentDefinition.Occurrences,1)
    ' Update the view.
    ThisApplication.ActiveView.Update
End Sub
Sub Iterate(Occurrences As ComponentOccurrences, Level As Integer)
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPart As ComponentOccurrence
'set rules to be ran
Dim sRuleName As String = "BASE_QTY_CHANGE_RULE 1"
'''Iterate through part occurrences in assembly
	For Each oPart In Occurrences
		Dim oFileName As String = oPart.Definition.Document.FullFileName
'Check to see if occurance is a Part
		If oPart.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
'Set part type to be changed.
			If oPart.Name.Contains("STR.") Then
				'Open Part document True opens visually.
					auto = iLogicVb.Automation
				Try
					'run desired rule
					auto.RunExternalRule(oDoc, sRuleName)
				Catch
					MessageBox.Show("Cannot find a rule with the name " & sRuleName & "." & vbLf & "Please try again.", "Open and run")
				End Try
		'''Close the document with SAVE (as False), without SAVE (As True)
					oDoc.Close(False)
	'recursively call sub to traverse through occurance if it is a subassembly
	ElseIf oPart.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Call Iterate(oPart.SubOccurrences, Level)
	Next
End Sub
Accepted solutions (3)
johnster100
ActiveDocument will not work if visibility is set to false.
If it's in iLogic then use:
asmDoc = ThisDoc.Document
I think that will work,
cheers,
John
DRoam
Using ActiveDocument should be fine, assuming you're running the rule from an open Assembly.
I believe the problem might be with the fact you're trying to Open and Close documents that are already open and being used by your assembly. The fact that those Part documents are occurrences in your active assembly means that they're already loaded into memory (in other words, opened). So you don't need to Open them. And closing them might cause issues because your assembly is using them.
I would make the following changes to your code (key change in blue -- a few other recommended changes in red/green):
	'Iterate through occurrences in assembly
	For Each oOcc As ComponentOccurrence In Occurrences
		'Dim oFileName As String = oPart.Definition.Document.FullFileName
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
			If oOcc.Name.Contains("STR.") Then
				'Get Part Document object.
				'Dim oDoc As PartDocument = ThisApplication.Documents.Open(oFileName, True)
				Dim oDoc As PartDocument = oOcc.Definition.Document
				Dim auto As IiLogicAutomation = iLogicVb.Automation
				Try
					'run desired rule
				Catch
				End Try
				oDoc.Close(False)
		ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			'Recursively call sub to traverse through occurance if it is a subassembly
			Call Iterate(oOcc.SubOccurrences, Level)
	Next
jzcrouse
Thanks for the input. I tried the suggestions. I do not believe it ThisDoc is working perhaps because the rules I am running are an external rules and not stored in the assembly.
DRoam
ThisDoc uses the active document if manually executed from an External Rule. If it's triggered by a document's Event Trigger, ThisDoc is the triggering document. So it should work fine.
Can you please post the error your getting? Or if there's no error, a detailed description of what's going wrong?
jzcrouse
Here is what I ran. No error message. I put a message box in after the rule should be run with the doc name and everything seems to be working correctly. Except the effects of my sRuleName are not taking effect in the specified parts as there were previously. It seems like the rule is running in the Assembly and not the part maybe? But its confusing since the oDoc displayname is the correct part itp
Private Sub Main()
    ' Update the view.
End Sub
oAsmCompDef = ThisDoc.Document.ComponentDefinition
'		Dim oFileName As String = oPart.Definition.Document.FullFileName
				Dim oDoc As PartDocument = oPart.Definition.Document
					Dim auto As IilogicAutomation = iLogicVb.Automation
				Try
					'run desired rule
					MessageBox.Show(oDoc.DisplayName)
				Catch
				End Try
	Next
End Sub
jzcrouse
ah figured it out. I was using
 Document = ThisApplication.ActiveDocument
in the rule i was trying to run. Changed it to Thisdoc.document and worked.
Thanks for your help!
