CANNOT SET A SKETCH ELLIPTICAL ARC TO PROFILE FOR EXTRUSION
tritranL9YYF
Message 1 of 1
tritranL9YYF
Hi guys,
I have a Function using VB.net to create an AISC W Shape. I have a problem with set the sketch to profile,
Here is my code:
Public Function CreateWSection(sec As Wsec) As PartDocument
        Dim R_k1_web As Double = sec.k1 - sec.tw / 2
        Dim R_kdet_flg As Double = sec.kdet - sec.tf
        Dim isVE As Boolean = False
        ''Convert WSections properties to inches
        Dim i_depth = sec.Depth * 2.54
        Dim i_D_depth = sec.D_det * 2.54
        Dim i_bf = sec.bf * 2.54
        Dim i_bf_det = sec.bf_det * 2.54
        Dim i_tw = sec.tw * 2.54
        Dim i_twdet_2 = sec.twdet_2 * 2.54
        Dim i_tf = sec.tf * 2.54
        Dim i_tfdet = sec.tfdet * 2.54
        Dim i_kdet = sec.kdet * 2.54
        Dim i_k1 = sec.k1 * 2.54
        'Try to get an existing instance of Inventor
        Try
            oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        Catch ex As Exception
            oApp = CreateObject("Inventor.Application") 'Create object if not exist
        End Try
        Dim WPart As PartDocument
        WPart = CreatePartTemplate()
        'Define Part Document Definition
        oCompDef = WPart.ComponentDefinition
        ' Set a reference to the transient geometry object.
        Dim oTransGeom As TransientGeometry
        oTransGeom = oApp.TransientGeometry
        'Make sure Inventor is visible
        oApp.Visible = True
        'Create a base sketch first on a workplanes
        Dim oSketch As PlanarSketch
        oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
        'Create AISC W properties on the XY plane
        ' 11               10
        ' 6     7     8     9
        '     12-     -14
        '     13-     -15
        ' 5    4-     -3    2
        ' 0                 1
        'Create reference construction line
        'oSketch.SketchLines.AddByTwoPoints(oTransGeom.CreatePoint2d(0, 5.0), oTransGeom.CreatePoint2d(0, -5.0))
        'oSketch.SketchLines.AddByTwoPoints(oTransGeom.CreatePoint2d(-5.0, 0), oTransGeom.CreatePoint2d(5.0, 0))
        'oSketch.SketchLines.Item(1).Construction = True
        'oSketch.SketchLines.Item(2).Construction = True
        'Define all sketchpoints
        Dim oSkPnts As SketchPoints
        oSkPnts = oSketch.SketchPoints
        Dim oP(0 To 19) As SketchPoint
        'Define all sketchlines
        Dim oLines As SketchLines
        oLines = oSketch.SketchLines
        Dim oLine(0 To 13) As SketchLine
        'Dim all sketchEllipArc
        Dim oSkElArcs As SketchEllipticalArcs
        oSkElArcs = oSketch.SketchEllipticalArcs
        Dim oSkElArc(0 To 3) As SketchEllipticalArc
        'Bottom flange
        oP(0) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_bf / 2, -i_depth / 2), False)
        oP(1) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_bf / 2, -i_depth / 2), False)
        oP(2) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_bf / 2, -i_depth / 2 + i_tf), False)
        oP(3) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_k1, -i_depth / 2 + i_tf), False)
        oP(4) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_k1, -i_depth / 2 + i_tf), False)
        oP(5) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_bf / 2, -i_depth / 2 + i_tf), False)
        oLine(0) = oLines.AddByTwoPoints(oP(0), oP(1))
        oLine(1) = oLines.AddByTwoPoints(oP(1), oP(2))
        oLine(2) = oLines.AddByTwoPoints(oP(2), oP(3))
        oLine(3) = oLines.AddByTwoPoints(oP(4), oP(5))
        oLine(4) = oLines.AddByTwoPoints(oP(5), oP(0))
        'Top flange
        oP(6) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_bf / 2, i_depth / 2 - i_tf), False)
        oP(7) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_k1, i_depth / 2 - i_tf), False)
        oP(8) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_k1, i_depth / 2 - i_tf), False)
        oP(9) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_bf / 2, i_depth / 2 - i_tf), False)
        oP(10) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_bf / 2, i_depth / 2), False)
        oP(11) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_bf / 2, i_depth / 2), False)
        oLine(5) = oLines.AddByTwoPoints(oP(6), oP(7))
        oLine(6) = oLines.AddByTwoPoints(oP(8), oP(9))
        oLine(7) = oLines.AddByTwoPoints(oP(9), oP(10))
        oLine(8) = oLines.AddByTwoPoints(oP(10), oP(11))
        oLine(9) = oLines.AddByTwoPoints(oP(11), oP(6))
        'Web
        oP(12) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_tw / 2, i_depth / 2 - i_kdet), False)
        oP(13) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_tw / 2, -i_depth / 2 + i_kdet), False)
        oP(14) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_tw / 2, i_depth / 2 - i_kdet), False)
        oP(15) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_tw / 2, -i_depth / 2 + i_kdet), False)
        oLine(10) = oLines.AddByTwoPoints(oP(12), oP(13))
        oLine(11) = oLines.AddByTwoPoints(oP(14), oP(15))
        'oLine(12) = oLines.AddByTwoPoints(oP(12), oP(14))
        'oLine(13) = oLines.AddByTwoPoints(oP(13), oP(15))
        '4 Elliptical Arcs
        Dim oPEA(0 To 3) As SketchPoint
        oPEA(0) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_k1, i_depth / 2 - i_kdet), False)
        oPEA(1) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_k1, i_depth / 2 - i_kdet), False)
        oPEA(2) = oSkPnts.Add(oTransGeom.CreatePoint2d(-i_k1, -i_depth / 2 + i_kdet), False)
        oPEA(3) = oSkPnts.Add(oTransGeom.CreatePoint2d(i_k1, -i_depth / 2 + i_kdet), False)
        'Dim UV2d As Sketch
        Dim UV2d As UnitVector2d = oTransGeom.CreateUnitVector2d
        oSkElArc(0) = oSkElArcs.Add(oPEA(0), UV2d, (i_kdet - i_tf), (i_k1 - i_tw / 2), -Math.PI / 2, Math.PI / 2)
        oSkElArc(1) = oSkElArcs.Add(oPEA(1), UV2d, (i_kdet - i_tf), (i_k1 - i_tw / 2), Math.PI / 2, -Math.PI / 2)
        oSkElArc(2) = oSkElArcs.Add(oPEA(2), UV2d, (i_kdet - i_tf), (i_k1 - i_tw / 2), Math.PI, Math.PI / 2)
        oSkElArc(3) = oSkElArcs.Add(oPEA(3), UV2d, (i_kdet - i_tf), (i_k1 - i_tw / 2), Math.PI / 2, Math.PI / 2)
        Dim WProfile As Profile
        WProfile = oSketch.Profiles.AddForSolid(True)
        'Define an Extrude feature
        Dim W_ExtrudeDef As ExtrudeDefinition = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(WProfile,
        PartFeatureOperationEnum.kJoinOperation)
        Call W_ExtrudeDef.SetDistanceExtent(120 * 2.54, PartFeatureExtentDirectionEnum.kSymmetricExtentDirection)
        'Add Extrude Definition to Features
        Dim W_Extrude As ExtrudeFeature
        W_Extrude = oCompDef.Features.ExtrudeFeatures.Add(W_ExtrudeDef)
Return WPart
    End Function
It always get error at the step Adding the sketch to Profiles.
Please help me.
Replies (0)
