Cannot Convert Inventor._Document to Inventor.AssemblyDocument
shiftctrl.io
shiftctrl.io
Hi All,
As I'm learning C#, I thought I'd play with converting some of my VB.NET stuff over to C# as practice. I'm getting jammed up pretty quick here, as I can't figure why I'm getting this error:
If I declare it as a Document instead of an AssemblyDocument, then I can't access the AssemblyComponentDefinition interface.
If I cast the ActiveDocument then the error goes away, but I get another message of a suspicious cast.
How do you normally going about getting the Active (assembly) Document via C#?
shiftctrl.io
Well, not sure what is going on with that suspicious cast alert, regardless - it works just fine as long as you cast the _Document to an AssemblyDocument.
